#1 Posted : Monday, 22 November 2004 10:34:38 AM(UTC)
Hi all
Would just like to canvass some opinion on this.
A local garage I use from time to time tends to put the new small type oil filters on a 202 when they do a grease and oil change.
The guy tells me they are the ones you normally put on a LS1.
Can anyone tell me if this is a good thing to do or should you stick to the original large type ones?
Thanks for any opinions
#2 Posted : Monday, 22 November 2004 4:28:08 PM(UTC)
I used to use them as well on the 202 when I had it. The oil pressure comes up quicker with a smaller filter & the lifters don't rattle as much.
The seem to work fine to me, but then I do change the oil and filter every 5000km.
For the la
#3 Posted : Monday, 22 November 2004 10:55:05 PM(UTC)
are you sure they are from an LS1? the ones i use are GM pt. no. 92142006, they were introduced on the VP 5L, and i belive the ryco equivilant is Z130, but i only use genuine ones
#4 Posted : Tuesday, 23 November 2004 3:36:12 AM(UTC)
#5 Posted : Tuesday, 23 November 2004 3:36:57 AM(UTC)
#6 Posted : Thursday, 25 November 2004 7:17:29 AM(UTC)
I use the short ones on my 253 in a HT because they give better clearance for the bottom radiator hose. A larger filter will naturally be better because of the larger area for filtration, which will allow longer intervals between changes. I chnage my oil
