#1 Posted : Thursday, 2 December 2004 9:48:01 PM(UTC)
OK thanks to the useful comments in my last posting I have now hooked up the HZ thermo fan and she works great, actually too well. It runs all the time once the car is started (key is in the on position), OK for this time of year but I won't want that in winter!! What would cause this, could it be a faulty relay or is the temp sensor stuffed?
Peter
#2 Posted : Thursday, 2 December 2004 10:46:51 PM(UTC)
The relay should pick up power of the A/C system and then from the negative side of the coil go to the temp sender. The switch part of the relay should pick up power from the battery, via a fuse and then go to the fan.
The folloowing is a list of po
#3 Posted : Thursday, 2 December 2004 11:36:41 PM(UTC)
Thanks Warren, yes it has the symptoms of point 3, as it's whirring away regardless of temperature, but does stop when the ignition is turned off. As I said it's not a bad thing this time of year where I live, temps are in the mid to high 30s usually, bu
#4 Posted : Friday, 3 December 2004 4:49:37 AM(UTC)
Aftermarket thermo switches (eg Davies Craig) have three male spade connectors- two of which are connected together. These two are usually very close together. If you have used these two connectors you may have bypassed the swith altogether which will cau
#5 Posted : Saturday, 4 December 2004 8:43:10 AM(UTC)
I was running twin thermos and found the points on the temp control switch were fusing together apparently because of the huge current that flows through. I ended up disconnecting one fan. Check the points are not fused together if they are separate them
#6 Posted : Saturday, 4 December 2004 11:48:28 PM(UTC)
I run my twin thermos through a relay. Saves the poor old switch from all those amps.
#7 Posted : Sunday, 5 December 2004 3:03:27 AM(UTC)
Doesn't really save the switch unless you put the relay after the switch
