#1 Posted : Wednesday, 22 December 2004 7:09:58 AM(UTC)
I just bought a low K one owner VP V6. It is dual fuel. But when running on petrol. idling at the lights, it seems to cough and miss occasionally. Doesnt stall, but just wondering where to start looking, fuel or electrical??
Other than that she runs sweet, but is a little down on power compared to my old VN.
#2 Posted : Wednesday, 22 December 2004 8:33:07 AM(UTC)
An early V6 coughing and missing is fairly common. Try the coil-pack as a starter, it is a known problem on them, particularly when they are run on LPG.
HTH...Dave
#3 Posted : Wednesday, 22 December 2004 9:29:07 AM(UTC)
So just unbolt the coil pack and try a new one??
#4 Posted : Wednesday, 22 December 2004 11:12:57 AM(UTC)
Is there any other way of checking this without going to the expense of a new coil pack??
#5 Posted : Wednesday, 22 December 2004 5:53:44 PM(UTC)
TRy a local wreckers. Should be cheaper than new. Maybe replace your leadset ($60.00 genuine GMH).
Do what I did....got rid of the car that HAD parts issues.
John
#6 Posted : Wednesday, 22 December 2004 6:28:09 PM(UTC)
I cant sell it,I just bought it. Surely it cant be that difficult to fix.
#7 Posted : Thursday, 23 December 2004 3:37:35 AM(UTC)
Hi Guys.
You mentioned it was running rough on petrol, what is it like on LPG ? If it's OK on LPG & only bad on petrol, the ignition system is probably OK, get your injectors cleaned.
A very common problem on dual fuel cars is that the fue
#8 Posted : Thursday, 23 December 2004 6:19:15 AM(UTC)
Hi Dr Terry. To be Honest with you it is a dog on gas. It wont take off from the lights smoothly, feels like it is running out of fuel. Then if I stick the right boot in a bit harder it takes off pretty well. I just assumed that was atuning prob with th
#9 Posted : Monday, 10 January 2005 8:55:55 AM(UTC)
even have a look at the throttle body, see if it is clean or dirty, i have the same problem, it even cough's sometimes hile i drive normally when i am going fast, but just one cough, but i think it is one of the EFI? modules, i thinks that what i mean.
