#1 Posted : Thursday, 30 December 2004 5:50:09 AM(UTC)
Any antenna guys here? I need some non-b/s advice.
thanks
#2 Posted : Thursday, 30 December 2004 6:41:25 AM(UTC)
Hi John,
Not really an antenna guy but if you are simply asking about a TV antenna then I can offer this. Had problems with bad reception for years (no SBS etc) then fitted a "masthead amplifier" to pre-existing antenna. Got crystal clear
#3 Posted : Thursday, 30 December 2004 8:56:59 AM(UTC)
Thanks Paul I am a bit dubious about having mains power go up the antenna.
I will look at one if it is the last chance. We have been givena DVD/VCR combo for Christams (given a DVD player actually but could not plug it in to our TV so took it back, got r
#4 Posted : Thursday, 30 December 2004 9:16:26 AM(UTC)
John,
My masthead amp is a GME KINGRAY MHW34GP which Jaycar actually sell for $90 - (Cat. No. LT-32.90, $89.50, page 295 of 2004 catalogue). You can also get these from TV installers a bit cheaper sometimes. There is no mains power going to the ant
#5 Posted : Thursday, 30 December 2004 12:05:04 PM(UTC)
Funnily enough I have that page open in front of me now. I see the one you mention. Although I see there is a unit for 2 tvs, I might get that one as the tv in the kids room needs a boost too.
#6 Posted : Thursday, 30 December 2004 5:34:21 PM(UTC)
Be careful of using the Jaycar Kingray booster with a W in the part number. This boosts both UHF and VHF. Normally VHF stations will have good signals and if you boost them you will swamp the UHF channels. Kingray sell a unit with the same part number, bu
#7 Posted : Friday, 31 December 2004 3:48:37 AM(UTC)
Thanks Byron useful information. but Newcastle is a bit far for me.
I will have to watch the uhf/vhf it, never realised that.
#8 Posted : Friday, 31 December 2004 6:19:02 PM(UTC)
The best thing to do is speak to antenna people in your area. Each location will have different solutions to problems. In Wollongong you only need a UHF antenna for the local stations, in Sydney you may need both UHF and VHR or you can get away with only
#9 Posted : Saturday, 1 January 2005 1:35:51 AM(UTC)
Johnperth,
Ring Hills (in Guildford Rd Bayswater if I remember rightly) or the Antenna Man, they should be able to tell you what antenna you need...even if you just get them out to give you a quote...
Cheers...Dave
#10 Posted : Saturday, 8 January 2005 10:51:22 AM(UTC)
I don't specialise in antennas but deal with them a little. I'm a tv repair man. It all depends as to if your 7, sbs and abc are on vhf or uhf. Using a masthead amp won't fix the problem if you are already recieving too much signal. All vcrs have an inbui
#11 Posted : Saturday, 8 January 2005 10:54:13 AM(UTC)
#12 Posted : Saturday, 8 January 2005 10:55:12 AM(UTC)
Another good guide is to look at what the neighbour's are doing - they are subject to the same signal conditions..
Matt
Guest (5)
This page was generated in 0.066 seconds.
