#1 Posted : Thursday, 13 January 2005 10:46:24 PM(UTC)
Hi all, whats the best way of removing a drum brake drum where the drum is stuck on the axle in the center???
I know its not the shoes holding it in due to a lip on the drum, its definately locked hard in the center.
Cheers Dre
#2 Posted : Thursday, 13 January 2005 11:48:31 PM(UTC)
Go for a drive and give the brakes a good warm up. Get home quick and take the wheel off. Apply some WD40 or similar to the hub(lots of it), and back the brakes right off. Use a wooden or rubber/nylon hammer to assist dislodging it. ( also, not saying you
#3 Posted : Friday, 14 January 2005 1:23:51 AM(UTC)
Yepp oodles of WD40 to the 5 wheel studs too !!
#4 Posted : Friday, 14 January 2005 5:46:18 AM(UTC)
You can lightly heat the drum with oxy-accetelene and it should nearly pop off ! otherwise bash it
#5 Posted : Friday, 14 January 2005 10:27:21 AM(UTC)
Put the wheel nuts on so they cover the threads in case you miss (screw the well o if you only put them on a couple of threads and nudge them they will go over sideways and stuff the threads) and belt the centre of the axle with a 5 pounder a couple of ti
#6 Posted : Friday, 14 January 2005 10:29:17 AM(UTC)
Also make sure you have slackened off the brakes.
#7 Posted : Saturday, 15 January 2005 3:00:48 AM(UTC)
Thanks for the advice all, that has certainly given me something to go on, much appreciated!
Cheers Dre
#8 Posted : Saturday, 15 January 2005 10:13:58 AM(UTC)
that's ok Dre we are all pretty good at giving gratuitous advice!
