#1 Posted : Sunday, 16 January 2005 1:02:01 AM(UTC)
Got a major problem with the yellow wire on the ignition switch.It gets hot and wants to melt everything.Once this wire goes into the main harness i can`t trace where it goes.I don`t have a wiring diagram so can someone please tell me where this wire goes too???
#2 Posted : Sunday, 16 January 2005 2:00:35 AM(UTC)
go to oldholden.com then look in the sheeds you will find wireing diagrams there just look around you wiil find sory cant be more exsact
 1 user thanked Guest for this useful post.
AC on 13/08/2022(UTC)
#3 Posted : Sunday, 16 January 2005 2:19:53 AM(UTC)
It looks like the yellow wire maybe the 12volt ign feed to the coil while cranking, and then in the run position the pink resistive 9 volt wire is then the feed to the coil.
#4 Posted : Sunday, 16 January 2005 9:34:09 AM(UTC)
Sounds like a dead short. Doesn't this one go to the starter? Not sure.
#5 Posted : Sunday, 16 January 2005 9:39:15 AM(UTC)
Just checked a Gregorys for the HZ V8, the yellow wire goes to the coil. It also connects to the pink resistor wire at the firewall connector (I think it's the firewall connector).
#6 Posted : Sunday, 16 January 2005 9:51:25 PM(UTC)
Please supply more info.
#7 Posted : Monday, 17 January 2005 4:57:21 AM(UTC)
thanks for the info ..........I ended up replacing the yellow wire, both under the dash and from the firewall connector to the coil...All is fine now.
cheers.
