#1 Posted : Thursday, 20 January 2005 11:52:25 PM(UTC)
I have a dual fuel HZ Premier that is hard to start when cold on gas. I have been advised it's because the standard points dizzy can't make a strong enough spark to ignite the gas when cold, so I always start on petrol. Anyway I've been looking at HEI systems from WB/VC/VH models but they seem to go for pretty big money or I miss out! I see the Mallory twin point systems available with matching coils quite often, are these a good compromise as they are much cheaper? Does anyone here run one, if so how hard are they to fit and how do they perform?
Peter
#2 Posted : Friday, 21 January 2005 9:18:16 AM(UTC)
Gas is always hard to start cold as the gas needs heat to de-liquify.
It's usual to start on petrol and after 5 mins go gas.
#3 Posted : Friday, 21 January 2005 8:50:38 PM(UTC)
That's true John, however my previous car a WB Stato with HEI ignition started quite well on gas even when cold and it was the same gas setup I have on my HZ wagon, a sprintgas system. I assumed the points ignition was the difference.
Peter
#4 Posted : Friday, 21 January 2005 10:50:31 PM(UTC)
Peter
I have a HZ 308 TH400 1-tonner on LPG. I fitted a blue motor HEI dizzy and coil. The Mallory units might be cheap but wait till you have to buy a rotor button and cap! My tonner runs a newgen mixer (the aircleaner style). To start it cold I tu
#5 Posted : Friday, 21 January 2005 11:02:53 PM(UTC)
Thanks Byron, some good info there thanks!! If you happen to have that Bosch setup please let me know, otherwise I'll hang out for a HEI setup.
Ta
Peter
#6 Posted : Saturday, 22 January 2005 9:11:31 AM(UTC)
Peter
I was just wondering what type of converter you are using. I have had gas powered cars since 1988 and all of them have had stock points ignition. Only the first one was a little hard to start cold and it became a lot worse when I moved to t
#7 Posted : Sunday, 23 January 2005 7:15:07 AM(UTC)
Thanks Greg, that's good advice, I had a new converter on my previous 308 (in a WB Stato) and it started fine on gas cold, I assumed it was the HEI ignition that was the difference, maybe it was the new converter all along!!
Peter
Guest (6)
This page was generated in 0.066 seconds.
