Gents<
I need some help on sorting out if the Body IDent.. Plate which came with a HK monaro that I brought is actually from a Monaro, I think it may be from a HK prem, but in saying that the 16677 part of the body number is in the original GMH Owners book which came with the car.
The plate reads:
Body HK737A-16677B Trim 1150-14X Paint 587-1704
Let me know your thoughts.
Hi Mon 1968.
That ID plate is from an HK Monaro GTS automatic, body made in Brisbane, that was painted Silver Mink Metallic & had Light Teal interior trim.
In HK the body number doesn't tell you if it was a 6 cyl or a V8, so in this case the car was |
Thanks Dr Terry, The monaro is a 186S with all of the details you replied with. I thought the body number should start with 80737, 80837 or 80337 for it to be a monaro but mine starts with HK737 ?? Is this common?? Regards and thanks Bradley
Normal for a Brisbane built HK. The 327 Monaro had HK837 on the BODY plate on Brisbane built examples. |
Thanks for the information.
