#1 Posted : Monday, 31 January 2005 3:31:41 AM(UTC)
Hi guys, can any one help?
What is the main difference between running a different ratio gear behind a 5 speed celica gear box powered by a 186? I've been told a 3.36 is better than a 3.55 and to stay away from a 3.08
#2 Posted : Monday, 31 January 2005 9:16:28 AM(UTC)
A 3.36 is a good alrounder especially with a 5 speed...a 3.55 will get away from the lights a little quicker (better acceleration) a 3.08 is more of a highway cruising diff (less revs at 100 km/hr)...I know a bloke with a 3.08 in his 186 powered HR ute an
#3 Posted : Tuesday, 1 February 2005 5:18:35 AM(UTC)
If Milton is not interested in 3:08 I may be
Matt (0431) 444-848
#4 Posted : Tuesday, 1 February 2005 10:02:41 AM(UTC)
Better to do the email thing.
[email protected]
BTW I'm on the Central Coast just north of Sydney.
#5 Posted : Thursday, 3 February 2005 3:27:27 AM(UTC)
As a HR has 13 " wheels and say a later Holden has 14" wheels the ratios multip[ly across.
3.36 with 13" wheels = 3.55 with 14"
3.08 = 3.36
2.78 = 3.08
GMH combos
GTR had 13" 3.08
HK to HZ auto 3.36
LC to LX
#6 Posted : Thursday, 3 February 2005 9:20:08 AM(UTC)
Thanks FastEHHolden,
The info is great and as you probably gathered I have been working hard trying to sort this one out. As I needed to change the whole thing I found one comp-lete and as it happened it had a 3.08 in it and I'm going to put itin and see
#7 Posted : Thursday, 3 February 2005 9:38:40 AM(UTC)
This is great info. Is the difference in the travelling or the taking off? And what about clutch wear is one more excessive than the other?
#8 Posted : Thursday, 3 February 2005 6:10:17 PM(UTC)
The smaller the number the less revs you will be doing for the same speed.
As for clutch wear, if you have a 3.55 and replace witha 2.78 it would be like converting say a 3 speed to a 2 speed with over drive. Taking off in secon each time.
I b
