#1 Posted : Sunday, 6 February 2005 1:50:52 AM(UTC)
Hi i have just came across a 350 Chev with the engine No Starting with the prefix 350M it is still fitted with the alloy tappet covers as fitted to the HT / HG Monaro. Condition unknown was in a boat and has been removed, suggesting it probably needs a full on rebuild. Any ideas on what it would be worth as is.It is complete but is running a Holley instead of the Quadrajet on the standard 4 bbl inlet manifold.
#2 Posted : Sunday, 6 February 2005 2:00:59 AM(UTC)
Could be very valuable if all the right bits are still there, or it could be of some value if it's just the block, or worth very little if it's rotted out from use in salt water. Email me and I can tell you what to look for. A friend of mine will be inter
#3 Posted : Sunday, 6 February 2005 6:02:54 PM(UTC)
The M may mean "Marine", as some of these engines were used exclusively for marine use.
I have a Volvo Penta sterndrive in my boat, and the engine is a Volvo Penta AQ211, which is in fact a Chev V8 engine.
Will check the eng number today.
