#1 Posted : Monday, 7 February 2005 4:39:33 AM(UTC)
guys, chasing info on years or models the blue motors came out in? and any variances in them to red motors, I have heard about the cast bracket holes for air cond etc but is that really the only diff? can anyone help
#2 Posted : Monday, 7 February 2005 5:38:13 AM(UTC)
Blue motor was in the VC and VH, Black motor is almost identical and was in the VK. The big differences were a fully counterweighted crankshaft, bigger better conrods, a HEI ignition system,a 2 barrel Varijet Carby and a 12 port head. There were numerous
#3 Posted : Monday, 7 February 2005 5:40:29 AM(UTC)
To the best of my knoledge- VC to VH modles. Better head flow, 4bbl carb and manifold, electronic ign, 9.2:1 for 5L, 9.0:1 for 4.2L The other thing is commodors have differant water pump shaft lengths due to belt location. Better motor than the red
#4 Posted : Monday, 7 February 2005 6:28:49 AM(UTC)
Hi HQLDEN.
Do you mean 6 cyl or V8 Blue Motors.
#5 Posted : Monday, 7 February 2005 8:57:06 AM(UTC)
Sorry Dr Terry, I did mean 6cyl
#6 Posted : Monday, 7 February 2005 4:36:57 PM(UTC)
WB Holdens also had a blue motor. They also had bigger clutches, and a few water passages different on the top of the block. The rods are basically the same as a 1973 Bathurst XU-1, except the rod bolts are slightly larger in the blue/black motor.
