#1 Posted : Wednesday, 9 February 2005 8:20:42 AM(UTC)
Interested to know if anyone could tell me on my hx wagon why the fuse for instr lights/brake lights blows when I pull on the headlight switch!!. All these lights work ok on their own until the above situation arises. I have replaced the headlight switch but the problem is still there. I have a multimeter, how can I test for resistance etc. I figure it may be an autoelec job but nothing has been done to the vehicle. The fault appears to have come out of nowhere...Thanks
#2 Posted : Wednesday, 9 February 2005 11:04:03 AM(UTC)
Andrew
Bit hard to tell exactly what’s going on remotely, but I suspect it may have something to do with the double-filament globes used in the brake/tail lights - that's the only obvious light on the face of it. These globes can do funny things if
#3 Posted : Wednesday, 9 February 2005 1:33:34 PM(UTC)
Also check that someone hasn't put a single filament bulb in the brake/tail-light dual filament holders...had this problem when I bought the Qute...
HTH...Dave
#4 Posted : Wednesday, 9 February 2005 8:07:01 PM(UTC)
If you haven't changed any bulbs for the problem to have started as mentioned below.
Have you got towbar wiring? this can often be the source of many woes.
#5 Posted : Thursday, 10 February 2005 8:57:29 AM(UTC)
Thanks everyone I will let you know the outcome. Just hope I dont have to drive at night!!
