7 Pages«<23456>»
#61 Posted : Monday, 18 June 2007 6:10:15 PM(UTC)
Hi Byron.
The Holden Suburbans had 4L80-Es.
The 6L80-E has only been on the US market since the 04 or 05 model year.
Dr Terry.
#62 Posted : Monday, 18 June 2007 6:10:15 PM(UTC)
Hi Byron.
The 6L80-E has only been on the US market since the '04 or '05 model year.
Dr Terry.
#63 Posted : Monday, 18 June 2007 10:21:09 PM(UTC)
Terry, took me a while to realise why you typed the bit about Suburbans as that is exactly what I was stating - then realised what I wrote was misleading. I meant that the Statesmans had a 6spd version of the 4L80-E and the Suburbans also had a 4L80-E.
Edited by user Monday, 18 June 2007 10:27:20 PM(UTC)  | Reason: Not specified
#64 Posted : Saturday, 14 July 2007 7:34:31 PM(UTC)
thanks byron for the info on 350 chev into hj holden atleast i know where i stand now also could you tell me my mate has a 253 engine trimatic very hard to run when cold takes 15 minutes before he can even drive it even if he stop for 2 hours it still tak
jabba Offline
#65 Posted : Tuesday, 17 July 2007 4:11:54 PM(UTC)
jabba
Not running when cold could be need for a choke, but may require larger jets or idle settings altered (maybe crack the secondaries slightly as well).
Another idea may be to go to a hotter range of plug. They will "get up to temperature" faster from co
#66 Posted : Wednesday, 18 July 2007 12:52:33 AM(UTC)
hey pretty random question. what is the best carby cfm to run on a 383 in a wb statesman with a turbo 400 box and a 3.55:1 diff?
boom Offline
#67 Posted : Wednesday, 18 July 2007 3:04:58 AM(UTC)
boom
a 600 holley is popular. i assume you mean chev '383' (its actually a 377).
If it doesn’t burn fossil fuels, it’s not a sport.
Edited by user Wednesday, 18 July 2007 6:03:45 AM(UTC)  | Reason: Not specified
boom Offline
#68 Posted : Wednesday, 18 July 2007 3:04:58 AM(UTC)
boom
a 600 holley is popular. i assume you mean chev 383 (its actually a 377).
#69 Posted : Wednesday, 18 July 2007 4:26:11 AM(UTC)
#70 Posted : Wednesday, 18 July 2007 10:03:07 AM(UTC)
thanks for the info on the 253 guys i will give that a go and see what happens let u know how i go
gunna Offline
#71 Posted : Friday, 7 September 2007 7:15:15 AM(UTC)
gunna
454 into my hx is ready to drop in. does anyone know if this motor will clear the power steering box? im hearing conflicting stories.also anyone out there has had any success with clearing the bonnet line as i want to avoid using a scoop. cheers.gunna
gunna Offline
#72 Posted : Friday, 7 September 2007 7:15:15 AM(UTC)
gunna
454 into my hx is ready to drop in. does anyone know if this motor will clear the power steering box? i'm hearing conflicting stories.also anyone out there has had any success with clearing the bonnet line as i want to avoid using a scoop. cheers.gunna
Sandman Offline
#73 Posted : Sunday, 9 September 2007 3:08:30 AM(UTC)
Sandman
Chev make a very low dual plane manifold for BBC. The runners almost go down where they meet the head. I'm not sure what cars they were made for. A friend had one on his Camaro but ditched it for a hi rise. He had to cut a hole in the bonnet then. It wasn
Sandman Offline
#74 Posted : Sunday, 9 September 2007 3:08:30 AM(UTC)
Sandman
Chev make a very low dual plane manifold for BBC. The runners almost go down where they meet the head. Im not sure what cars they were made for. A friend had one on his Camaro but ditched it for a hi rise. He had to cut a hole in the bonnet then. It wasnt
#75 Posted : Sunday, 9 September 2007 7:59:30 AM(UTC)
hi guys i no this has been asked befor but im just wanting to no what will it take to get a rwc / rego on a hq prem with a 454 bbc will it need Engineers report? if so cost? i just want to run petrol no gas for me thanks.
#76 Posted : Sunday, 9 September 2007 7:59:30 AM(UTC)
hi guys i no this has been asked befor but im just wanting to no what will it take to get a rwc / rego on a hq prem with a 454 bbc will it need Engineer's report? if so cost? i just want to run petrol no gas for me thanks.
gunna Offline
#77 Posted : Tuesday, 15 January 2008 6:37:09 PM(UTC)
gunna
guys in relation to fitting a 454 into my hx i encounted the following dramas.
1 the factory air con box did hit the pacemaker tri y extractors so it had to be cut to suit and aftermarket under dash air con will now be used.
2 the standard sump was hard
#78 Posted : Wednesday, 16 January 2008 5:17:27 AM(UTC)
The Edelbrock Torker 2 Manifold is the best manifold for carby/bonnet clearance with a BB Chev. Lower than the Performer manifolds. Everything fits under the bonnet.
#79 Posted : Wednesday, 16 January 2008 6:25:05 AM(UTC)
This is the way to do it. If I had a spare $30k id have this tomorrow. http://cgi.ebay.com.au/1...DVWQQrdZ1QQcmdZViewItem
______________________________________________
#80 Posted : Wednesday, 16 January 2008 6:25:05 AM(UTC)
This is the way to do it. If I had a spare $30k i'd have this tomorrow. http://cgi.ebay.com.au/1...DVWQQrdZ1QQcmdZViewItem
7 Pages«<23456>»
This page was generated in 0.204 seconds.
