Holdenute Offline
#1 Posted : Thursday, 3 March 2005 8:20:20 PM(UTC)
Holdenute
Hi guys,
Love the look of the new site.
I've had the intermittant wiper switch and relay set-up installed in my ute for ages now, but haven't got around to making it work yet. the problem I've got is after plugging everything in, as soon as I turn it on with the wipers working it blows a fuse. I can't see anything obvious.
This also happened in my other WB ute I owned quite a few years ago, but again, never got around to fixing. Gee I'm lazy.
Anyone got any tips?
Thanks, Steve.
Never late in a V8
Never late in a V8
#2 Posted : Monday, 7 March 2005 1:57:39 AM(UTC)
Exactly the same thing here ?? Might be we have wired them up wrong ?
I will be following this thread for an answer. Mines been like it for 6 years !
Holdenute Offline
#3 Posted : Monday, 7 March 2005 7:18:09 PM(UTC)
Holdenute
At least I'm not the only one :)
Surely someone must have an idea.
Also let's see some more photos in your profiles guys.
Never late in a V8
Never late in a V8
#4 Posted : Wednesday, 12 October 2005 8:30:35 AM(UTC)
any luck with it yet ?
Mr Void Offline
#5 Posted : Wednesday, 12 October 2005 8:21:05 PM(UTC)
Mr Void
I really don't know the specific problem but I would presume there is a short somewhere.
As a trial I would 'un-mount' the switch and relay if they are screwed to any metal surfaces and then try it all out again.
In other words, just let the wiring hold
___________________
#6 Posted : Thursday, 13 October 2005 12:02:07 AM(UTC)
hi
try swapping the leads around that plug into the harness ... the nephew had the same problem with his WB van, did the swap, and hey presto, all cured ...
cheers frnak
#7 Posted : Thursday, 13 October 2005 1:37:58 AM(UTC)
I have installed a couple of these ofver the years and never had one blow up. Installation should be as follows.
Find white wire to wiper motor and in the line there shall be a plug, unplug nad then plug in the white wires coming from the relay box. Yo
Rhys Offline
#8 Posted : Monday, 17 October 2005 7:41:32 PM(UTC)
Rhys
Hey Guys
Yes I had the same problem in my WB Van. Plugged everything in and kept blowing fuses. Turned out the dash wiring loom had the male and female connectors on the white wiper wire around the wrong way.
Didnt have to cut any wires - I just remov
Edited by user Monday, 17 October 2005 7:44:35 PM(UTC)  | Reason: Not specified
#9 Posted : Monday, 17 October 2005 10:26:54 PM(UTC)
I pulled a totally original 1984 WB Kingswood ute apart a few months ago. It had factory intermitent wipers, and the way the harness was run it must have been put in before anything else. The dash and air ducts had never been removed.
