#1 Posted : Sunday, 6 March 2005 11:19:55 PM(UTC)
Hey, I just wanted some feed back on this idea. Can the EFI 4.0 SOHC head be fitted to early model 250 X-flo heads. Obviously I would have to modify the original crank for a timing pulley, I'd possibly go belt driven instead of chain. Can it be done, are the head bolts simmilarly possitioned?
#2 Posted : Monday, 7 March 2005 7:54:31 AM(UTC)
Wont a belt slip if you use it instead of a timing chain tho?
#3 Posted : Monday, 14 March 2005 11:47:00 PM(UTC)
No, timing belts are similar to glimmer drive belts and run a sprocket type gear and a belt with teeth. All I need to know is if the head studs and chyamber spacing will be similar
#4 Posted : Tuesday, 15 March 2005 8:23:10 PM(UTC)
there was a bloke who designed and made a few dohc heads for the x-flow a few years back,i don't think they ever went into full blown production as i have never seen much on them.street machine and another mag had the stories,the cars(1 was a yellow xd ut
#5 Posted : Wednesday, 16 March 2005 12:01:00 AM(UTC)
That would have been Krogdahl (sp?) Engineering. I think that they cost about $5000 a go though.
#6 Posted : Wednesday, 16 March 2005 6:11:34 AM(UTC)
Yer I read about them in SM aswell, I'm only asking this question because I've got an engine of each, I'm rebuilding the 250 x-flo as the OHC 4.0i put a leg outta bed and I can't be bothered fixing the hole in the block. Being the same capacity i thought
#7 Posted : Wednesday, 16 March 2005 7:30:00 PM(UTC)
At a guess I would say that Ford left the bore spacing & head stud placing the same. I am basing this on the theory that they could not even be bothered to move the distributor to a decent location when they went OHC so why would they waste money on chang
#8 Posted : Friday, 18 March 2005 4:37:58 AM(UTC)
The thought never even crossed my mind to compare head gaskets. Cheers. I thought the studs might be diferent because they have to clear the cam instead of rockers but I havent looked so I hope your right.I'm getting another 250 block next week off a mate
#9 Posted : Friday, 18 March 2005 7:45:22 AM(UTC)
why not put all the ohc engine in??
#10 Posted : Thursday, 24 March 2005 4:51:06 AM(UTC)
I can't put all the OHC engine in beacause it got a gut full of water one day when a road was slightly flooded, and last time I checked water don't compress!
Result; One shattered piston
One bent conrod
And one hell of a hole in the
#11 Posted : Wednesday, 13 April 2005 8:26:46 AM(UTC)
I suggest go to a parts shop and compare head gaskets for the 2 engines
Fastlane Administrator
Guest (11)
