#1 Posted : Sunday, 20 March 2005 1:51:43 AM(UTC)
G'day All,
My HX Tonner has a bad grating sound eminating from the rear end, mainly on take off and especially if taking off while turning to the right. I checked all the shackle bushes and the big U-bolts holding the axle to the springs, and the shock bushes etc and everything seems kosher back there, does anybody have any idea what it might be, it drives me nuts and I've had it up on the ramps, jacks and everything else to try and see whats happening with no luck. Any advice will be greatly appreciated, thanks.
Jim Briar Hill Offline
#2 Posted : Sunday, 20 March 2005 2:18:12 AM(UTC)
Jim Briar Hill
Hi Russell. Have you had a good look at the bearings ( with the drums off) are you running druns or discs? are the shoe's loose? is their any scrub marks on the inner walls of the tires? Has the tray got any odd bits of steel sticking out that might be sc
#3 Posted : Sunday, 20 March 2005 5:42:13 AM(UTC)
Wouldnt it be a case for a standard diff (not LSD) to have the driven load on one bearing at take off ? So yes it could be wheel bearing. Better check it now B4 it decides to go altogether.
FWIW John
RussVRute Offline
#4 Posted : Sunday, 3 April 2005 9:30:18 PM(UTC)
RussVRute
G'day All,
First of all I'd better tell you,I am russellsydney, I just changed my handle when I officially signed up to the forum, but what I wanted to say is, I checked the wheel bearings and they are fine, checked everything for tightness, and everyt
RussVRute Offline
#5 Posted : Monday, 4 April 2005 2:51:21 AM(UTC)
RussVRute
Well Hallelujah I finally tracked the noise down to my rear engine mount , when I got under the car and jiggled the tail shaft a bit the noise happened again and it sounded like it was coming from the rear of the engine, so I grabbed the gearbox and shook
#6 Posted : Wednesday, 6 April 2005 3:30:22 AM(UTC)
Jim Briar Hill
Hi Russ good to get an end to a problem, there is some stuff that I used years ago but the name of it has gone, a good auto parts shop will be able to help you. Like greese but will not degrade the rubber. Strage how noise can travel through a car and com
RussVRute Offline
#7 Posted : Saturday, 9 April 2005 12:49:44 AM(UTC)
RussVRute
G'day All,
Changed the rear mount yesterday (and the two front ones for good measure!)and the noise is finally gone thank goodness! took a while but I got there. Cheers.
#8 Posted : Saturday, 9 April 2005 2:56:38 AM(UTC)
SEE FASTLANE WORKS !!!!!!!
