GMH1975 Offline
#1 Posted : Wednesday, 23 March 2005 2:56:39 AM(UTC)
GMH1975
Hi everyone.
Sorry but im going to sin and put a ford part in my beloved Hx Kingswood sedan since it seams cheaper than getting a 10 bolt LSD.
What i want to know is if there is a 9 inch diff thats is close to the width of a Kingswood diff.
Im basicly after one thats the same width or no more than an inch narrower.
Want this to cut down on cost to convert to fit a HX.
Anyone know if any certain ford came with a 9 in to suit these specs?
Thanks in advance Christopher
Not the BLOODY Kingswood
#2 Posted : Wednesday, 23 March 2005 3:30:44 AM(UTC)
Hi GMH1975.
The XA/XB/XC Falcon is very close to the same width as an HQ-WB rear axle. The XW/XY is about 1.5" narrower, which sometimes allows wider wheels to be fitted, depending on their offset.
When you get it fitted get a pro to weld the bracke
#3 Posted : Wednesday, 23 March 2005 3:36:46 AM(UTC)
XA, XB, XC.
What you need to do is cut the ends off the axle tubes and weld on Holden ends, plus weld on the Holden mounts. If you get the tubes the right length VN Commodore axles will bolt straight in, and the Commodore discs will also bolt on, or wi
#4 Posted : Wednesday, 23 March 2005 3:55:22 AM(UTC)
Was speaking to a fellow HQ owner the other day on this exact topic. He didnt gain much from the conversion. A little extra effort for little return. And he had a Q that had serious grunt ie ram tunnel nitrous Ford diff etc.
His words were dont dont bo
#5 Posted : Wednesday, 23 March 2005 9:58:45 AM(UTC)
For normal street use don`t waste your money.
GMH1975 Offline
#6 Posted : Friday, 25 March 2005 8:10:13 PM(UTC)
GMH1975
Thanks for all the info guys.
Spoke to my mechanic and he also says that the old 10 bolt with lsd will be strong enough aslong as i dont do full on static BURNOUNTS and rollbacks.
So i gues i will be getting some prices for a reco LSD set up.
Does any
#7 Posted : Friday, 25 March 2005 8:25:38 PM(UTC)
They are made in Australia, and bits are scarce. Look for a VK V8 diff and get the bits out of it.
#8 Posted : Saturday, 26 March 2005 2:37:36 AM(UTC)
If you are producing decent power go the 9 inch, the only people trying to tell you otherwise are those die hard people that would rather spend hours replacing centres and axles than say they have a ford part in there holden. Compare the size difference i
#9 Posted : Friday, 1 April 2005 6:11:46 AM(UTC)
he`s not building a drag car! even so a few guys in sa have camaro`s that lift the front wheels off the ground in 2nd gear and use 12 bolt saliburys with no dramas , so there are other GM diffs than a 9 inch out there to handle a bit of power .
GMH1975 Offline
#10 Posted : Friday, 1 April 2005 8:30:38 AM(UTC)
GMH1975
Excuse my stupidity but has CLOUDY mistyped 12 bolt instead of 10 bolt or is their actually a 12 bolt that is available and if so what are they out of???????
#11 Posted : Friday, 1 April 2005 9:04:14 AM(UTC)
GM vehicles like Pontiacs and Chevs. Were a production option on HK,HT and HG 81837 vehicles. Characterised by the 12 bolts that hold the crownwheel to the carrier, exactly as per a 10-bolt Chev (HK,T.G) or 10-bolt Holden (HQ-VK/WB) with 10 bolts on the c
GMH1975 Offline
#12 Posted : Friday, 1 April 2005 9:28:03 AM(UTC)
GMH1975
So is it posible to use new 10 bolt parts imported from the states in an australian 10 bolt?
I had my diff rebuilt 5 years ago when i first started building my car .
once i finaly got the car back on the road i noticed the diff was still making the sli
#13 Posted : Friday, 1 April 2005 6:13:49 PM(UTC)
Thankyou for explaining that byron , I have a 12 bolt in my 66 pontiac parisienne ( aust assy).
#14 Posted : Saturday, 2 April 2005 2:02:02 AM(UTC)
Different diffs.
GMH1975 Offline
#15 Posted : Saturday, 2 April 2005 2:33:15 AM(UTC)
GMH1975
Thanks guys
at the moment the car is powered buy a 180kw injected motor and turbo 700.
I will stay true to the general and get an LSD center for the old 10 bolt.
Later on i would like to go with a stroked 308 with blower posibly nitros and if that day
This page was generated in 0.243 seconds.
