#1 Posted : Friday, 25 March 2005 11:58:20 PM(UTC)
The old ute has 253blue backed by a m21 4sp with a ford 9 inch diff at the rear. Wish to know if there is a tailshaft that will fit without having to be cut. measured the tube to be approx. 143cm. Can aquire adaptor uni joints for holden shaft to ford diff.
Any assistance would be appreciated
#2 Posted : Saturday, 26 March 2005 5:31:05 AM(UTC)
A HQ-HZ TH400 ute/van/wagon/statesman shaft might go close. If it is the right length you'll need a 1-tonner front yoke as the TH400 shaft uses 1.125" unis on the front, same as 1-tonner. You'll also need the adapter uni for Holden V8 1" uni to Ford 9" un
