#1 Posted : Sunday, 27 March 2005 6:14:54 AM(UTC)
I have a VK Calais with a VN 5.0lt in it and it wont start. It was all ok until i moved the dizzy around to undo the dizzy cap clips to replace the rotor button. Thats all i have touched, now it has no injector pulse when cranking, only when you 1st turn the key, which primes the injectors. Im stuck for ideas. It does not have theplug for the tech 1 tool or a diagnostic plug. So i have spark, but jection pulse while cranking. I heard that the dizzy have to be spot on for it to start, eg 10 deg BTDC otherwise the whole injection curve will be out. Any help appreciated, saves me towing to the auto elec, Cheers
#2 Posted : Sunday, 27 March 2005 9:05:06 PM(UTC)
is the dizzy back to the correct spot timming wise, i think the injector pluse and spark are related, check the ignition moudle.
#3 Posted : Monday, 28 March 2005 12:52:48 AM(UTC)
As far as i know, the dizzy isas close as i can get it, cant check it cos it wont start. What do i check for referring to the ignition module? i have cleaned allthe connectors under the bonnet and still nothing, need and auto elec dammit. if you have the
#4 Posted : Monday, 28 March 2005 7:57:32 AM(UTC)
Thinking logically the spark should come after the injection, remember the piston is still on the way up (just) when the intake valve is still open for the fuel injection, and firing would take place just before (10 deg) TDC, so if the injectors are pulsi
#5 Posted : Monday, 28 March 2005 8:01:10 AM(UTC)
Second thought, have you checked all the electrical connections it might be something stupid like knocked a wire off somewhere.
#6 Posted : Monday, 28 March 2005 8:45:00 AM(UTC)
Johnperth, i have checked the connection around the motor and still cant find anything wrong, so once again, im stuck. I wanted to figure it out myself but it looks like i wont be able to. All outof ideas and patience, so i moved onto my stereo until the
#7 Posted : Wednesday, 30 March 2005 11:07:13 AM(UTC)
If not too late here....Get number one cylinder to 10 deg before TDC on compression stroke. Pull number 1 plug, reconnect it to lead and place on motor so you get a good earth (probably help if it is a bit dark too...). Turn on ignition, then turn dizzy b
