eskimo_joe777 Offline
#1 Posted : Tuesday, 29 March 2005 4:20:36 AM(UTC)
eskimo_joe777
Im just wondering if i end up welding some metal into where the windows were on my panelvan if it will srink or warp the around the window? thought i would ask instead of doing it and finding out the hard way! Any info would be good.
Cheers justin
#2 Posted : Tuesday, 29 March 2005 4:38:15 AM(UTC)
Hi justin.
Yes it will warp.
Also you've taken on a very difficult job there, even the pros have trouble getting it right.
I think that windows in the side looks a lot better than holes that have been obviously patched up.
Dr Terry.
Taz2 Offline
#3 Posted : Tuesday, 29 March 2005 4:19:43 PM(UTC)
Taz2
Depends on how you do it....spot or puddle weld using mig or a henrob torch is best.
You need to take your time and do alternating welds to minimise heat build up. Trying to weld all round would be disasterous :-(
This is one place where minimal filler
In thrust we trust
#4 Posted : Tuesday, 29 March 2005 9:13:05 PM(UTC)
I have used panel glue, its called FUSOR no distortion and you wont seperate it. Make your patch bigger than the hole the use a rebate tool on the patch to make it fit the hole from behind. Then pop rivet the patch in place with a rivet in each corner to
666 Offline
#5 Posted : Tuesday, 29 March 2005 11:39:30 PM(UTC)
666
Rogo, Does this work better than Fibreglass ?
666
666
#6 Posted : Wednesday, 30 March 2005 12:21:10 AM(UTC)
Is what part better than fibreglass ?
The fibrefill used for initial filling of the rebate gap after the patch is glued in is a form of fibreglass. There is no substitute for the glue except for another brand of glue or a welder !
Dont even think of
#7 Posted : Wednesday, 30 March 2005 5:16:43 AM(UTC)
eskimo_joe777
Thanks for the info it was really helpful. i might get me mate who's a panelbeater to give it a go for me and see how we go!
#8 Posted : Wednesday, 30 March 2005 5:25:10 AM(UTC)
Cool,
if your mate wants any advise send me an email, I have done it a fair few times now and have pretty well perfected it.
[email protected]
#9 Posted : Wednesday, 30 March 2005 6:02:55 AM(UTC)
Another Panel Boning Adhesive that does a really great job is 3M Automix. We glued in rust repair panels around the wheel arch on a HQ as well as the floor section, these products are better than weld as again there is no wraping. Lots of the more expensi
#10 Posted : Wednesday, 30 March 2005 9:15:49 PM(UTC)
eskimo_joe777
Where is the bset place to go get the panel glue? just an auto paint shop or do i go to a panelbeater/auto repair place?
And any idea's as to how much will it cost me in glue to do the 4 back windows?
Cheers Justin
#11 Posted : Wednesday, 30 March 2005 11:13:25 PM(UTC)
Have a look at the 3M products site for Australia.
#12 Posted : Thursday, 31 March 2005 3:18:20 AM(UTC)
I just buy mine from a paint & panel beating supply shop. It was around $30 per tube and depending on the size of your windows 3 tubes may be enough. You may have to hire the special gun to apply it as it mixes the 2 parts as you squeeze the trigger. The
#13 Posted : Wednesday, 4 April 2007 7:19:07 AM(UTC)
mate if u have a mig and the no how u can tack it in say every 25mm then oxy it the rest of the way u wont need a henrob for that plain old oxy with no 4 tip will do the jop if u cant use a oxy can finish off with the mig less heat.where r u what state /
VL05 Offline
#14 Posted : Wednesday, 4 April 2007 8:30:04 AM(UTC)
VL05
Just a question from the less educated and perhaps a lazier method. Would it be possible to lap join a sheet larger then the hole on the inside of the van then fill the low level with fibreglass or weld an additional sheet on top of the lap-jointed sheet?
WANTED: GTS rims, seats and mirrors to suit HJ.
#15 Posted : Tuesday, 10 April 2007 9:40:40 PM(UTC)
I have just removed the windows from my HQ Sandman resto. Cut the entire roof off and fitted another windowless top from a donor 74 van. Perfect, would not do it any other way and a hell of a lot easier.
hainzy Offline
#16 Posted : Wednesday, 11 April 2007 1:12:33 AM(UTC)
hainzy
Gday cannon.
hey mate ive been thinking about doing the same thing. Did you just cut it at the seams where it joins the ute body? Where did you cut it from the cabin roof? Was it relativly easy or a major pain? ive been thinking about doing this to my HZ
