#1 Posted : Tuesday, 5 April 2005 5:08:34 AM(UTC)
hey i have a stock xf falcon gl, and was wondering will an xf spack/ fairmont ghia instument cluster will go in without hassels, is all the wiring loom for the electronic dash already their?? thanks guys
#2 Posted : Wednesday, 6 April 2005 12:10:32 AM(UTC)
the wiring is there for the s pack gauges the will fit right in. not 100% on the fairlane/fairmont Ghia they should do. your stock Falcon wiring has the wires for the tacho and oil pressure. you will need to fit an oil pressure sender which is different t
#3 Posted : Sunday, 8 May 2005 4:33:54 AM(UTC)
Saturn,
If i were you id stay with what you have got. I,ve had a XF falcon "s" pac frome new in 1985. From the first few weeks I had the car this cluster unit was nothing but trouble for me. I had it back at Ford under warranty but still got rippe
#4 Posted : Monday, 23 May 2005 3:14:55 AM(UTC)
Hello
Sort of along the lines of the posting, my son's XF S pack's gauges play up. The fuel gauge reads accurately, then it decides to flah on empty, etc, etc. He has been told that the earthing is the problem. Put a wire to the gauges and the problem mi
#5 Posted : Monday, 23 May 2005 10:08:30 PM(UTC)
I had the same problem.
I fixed mine by resoldering all the joints on the PCB that the gauges are mounted on. You can ensure the earth is good at the same time.
My problem was with the connector for the wiring harness, which had many broken solder
#6 Posted : Tuesday, 24 May 2005 2:02:41 AM(UTC)
Like I said, I have had it repaired by professionals and after that date you can keep your fingers crossed for 1-(3 if your very lucky) years before it plays up again. I have all the reciepts to prove it. These gauges are bad news. As for earthing termin
#7 Posted : Wednesday, 25 May 2005 8:03:02 AM(UTC)
brakeslights stop working repaired switch workers then stopworker
#8 Posted : Wednesday, 25 May 2005 11:22:17 PM(UTC)
Ahh, my cluster was the basic setup - no digital stuff (except clock).
#9 Posted : Saturday, 28 May 2005 4:36:36 PM(UTC)
my headlight relay is shot, but the only probs ive had with my xf instrument cluster is the clock
#10 Posted : Sunday, 29 May 2005 8:33:51 AM(UTC)
IF it aint broke don't fix it
#11 Posted : Sunday, 29 May 2005 10:06:19 AM(UTC)
saturn it can be done, im pretty sure it aint much trouble, as long as its calibrated right
#12 Posted : Tuesday, 25 July 2006 4:45:20 AM(UTC)
I have put one in my ute. It works OK once I put the correct oil sender in but before that the volts were flashing. I had to remove the oil light from the dash as it would not go out. It was working well in the other dash. I don't have much trouble with i
#13 Posted : Sunday, 13 August 2006 2:26:01 AM(UTC)
it will work i have done it u dont need to change a thing
#14 Posted : Friday, 18 August 2006 10:50:02 PM(UTC)
THE XF FAIRMONT GHIA CLUSTER WILL GO IN TO ANY XF,BUT FOR THE FUEL GAUGE THERE RATED AT A 80 LITRE TANK.YOU'LL ALLSO HAVE TO REMEMBER THE FAIRMONT GHIA WAS ELCTRONIC FUEL INJECTED SYSTEM THAT RAN A EEC-IV
#15 Posted : Tuesday, 22 August 2006 7:12:14 PM(UTC)
My odometer failed about 6 months ago. yesterday I discovered that nothing works now. Not even the clock. Anybody got any suggestions?
#16 Posted : Saturday, 16 September 2006 11:05:45 PM(UTC)
ef on gas ,idle bad on petrol but good on gas.have changed map sensor and done injectors, what else could it be .need car to be ok , 4 kids
#17 Posted : Monday, 18 September 2006 11:19:16 PM(UTC)
Fil. My EB started doing this. Turs out the petrol had absorbed water. I spent $3.50 & poured a litre of metho into the tank & ran it completely out of petrol. All is sweet now.
Another cause could be a leak in your inlet manifold. Gas forgives this
#18 Posted : Friday, 29 December 2006 12:10:08 AM(UTC)
i have a xf ford ute witch i rebuilt i want to use another ford instrument cluster does anybody know witch one will fit i dont care if i have to rewire it
#19 Posted : Friday, 29 December 2006 1:19:19 AM(UTC)
HOLDEN WINS, JAM THAT UP YA FORDIES
#20 Posted : Saturday, 30 December 2006 11:29:44 PM(UTC)
Make your own cluster... seriously go talk to the lovely folks at your local AutoBarn. then you can get exactly what guages you want, the price maybe a bit higher but the result is great and individual... well thats what i am doing anyways. =)
Your loc
