#1 Posted : Tuesday, 5 April 2005 5:57:46 AM(UTC)
hi does ne1 no if all vn 5l autos came out wif T700 and how can you tell the difference.
Taz2 Offline
#2 Posted : Tuesday, 5 April 2005 7:18:41 AM(UTC)
Taz2
To the best of my knowledge all auto 5l VN's were T700
In thrust we trust
#3 Posted : Tuesday, 5 April 2005 8:11:11 PM(UTC)
whats involved in putting a T700 in a WB van , it would be going on a 5.0 Turbo pattern block from a HZ.
#4 Posted : Tuesday, 5 April 2005 10:18:00 PM(UTC)
I don't believe it's real hard. Just make sure you don't get a computer controlled box. You need to fabricate a rear mount, which is only a slightly modified trimatic/4/3speed one and shorten a trimatic tailshaft to suit. The box should use a TH400/TH350
#5 Posted : Wednesday, 6 April 2005 3:21:23 AM(UTC)
Hi Guys.
Yes, Byron is correct al VN/VP V8 autos were TH700.
They had a cable TV control similar to a TH350.
I've fitted one to an HZ 308 in place of a TH 400.
I used a TH350 crossmember & tailshaft. Because the box is slightly longer, I mount
#6 Posted : Wednesday, 6 April 2005 10:10:26 AM(UTC)
thanks guys
#7 Posted : Wednesday, 6 April 2005 7:31:38 PM(UTC)
They are nowhere near as tough as a TH400, and heaps dearer to rebuild. If you tow a lot I'd stick with the 400. If you want overdrive stick a 2.78 or 2.6 diff in it. The 308 should have sufficient grunt to push it. a 3.08 diff with a 0.85:1 overdrive is
#8 Posted : Thursday, 7 April 2005 8:09:43 AM(UTC)
Whats the most common way of getting the convertor to lockup when you are running these boxes behind the older motors? and is there any easy way to tell if a T700 is computer controlled or not?
- Adam
#9 Posted : Thursday, 7 April 2005 9:33:29 AM(UTC)
You can fit a switch, but if you forget to flick it off you'll burn the TCC.
If you know someone who is an electronics nut, you can probably get them to build you a little frequency detecting circuit, that will flick an output high or low above & below c
Edited by user Thursday, 7 April 2005 9:38:05 AM(UTC)  | Reason: Not specified
#10 Posted : Thursday, 7 April 2005 10:30:54 AM(UTC)
I`ll stick with the T400 , the van has a 3.55 diff but I have a 3.08 sedan diff to get converted for better hwy driving.
