#1 Posted : Wednesday, 6 April 2005 9:10:25 PM(UTC)
I have a rattle noise which seems to be coming from the front of the crank, It sounds more like something rattling on a panel, I have checked out the harmonic balancer and that looks fine and replaced the timing chain. It mainly does it when it is cold and under load, if you take off easily it isn't as bad. Does anyone have any ideas?
#2 Posted : Thursday, 7 April 2005 2:21:33 AM(UTC)
it might be an exhaust part rattling? iv had that happen to me b4 on 4cycl motors
#3 Posted : Thursday, 7 April 2005 7:20:29 PM(UTC)
Thanks qld I've checked all that out and can't find anything, it makes the noise when you are stoped with your foot on the brake and accelerate at the same time without moving.
#4 Posted : Thursday, 7 April 2005 7:43:36 PM(UTC)
Is it a sort of knocking noise?
#5 Posted : Friday, 8 April 2005 5:03:42 AM(UTC)
sounds like it could be a spun bearing as iv had that prob b4 if you got the time drop ya sump and chek the rod caps for movement and if thats ok chek ya main bearing caps
#6 Posted : Friday, 8 April 2005 6:17:43 AM(UTC)
its about to blow its load
6pak Offline
#7 Posted : Friday, 8 April 2005 10:34:06 AM(UTC)
6pak
Hi Glen, This is a dumb question but I'll ask it anyway. Have you checked that the engine isn't pinging? You're comment about the noise only occuring under load and being less apparent if you take it easy sort of points to this problem.
#8 Posted : Friday, 8 April 2005 11:50:49 AM(UTC)
Here's another stupid question. Is it more a scraping noise than a banging? If so it could be something as simple as a worn fan belt. Run some dry soap along the sides of the belt and check the tension. Might save you having to pull the sump off and n
#9 Posted : Saturday, 9 April 2005 12:12:41 PM(UTC)
I dont think its a knocking noise its more of a tiny noise as if you had a pice of tin spining around and hitting something
Origina
#10 Posted : Saturday, 9 April 2005 12:14:35 PM(UTC)
Thanks but its too loud to be pinging
#11 Posted : Saturday, 9 April 2005 12:16:10 PM(UTC)
Ive ran it with the belt off so its not the belt.
#12 Posted : Saturday, 9 April 2005 7:38:00 PM(UTC)
just a thought ...is the motor running rough on idle?...running rough under accelaration?
what about stuffed timming chain, although i did think pingin may have been the prob also!
tones
long live the coupe!
