#1 Posted : Sunday, 10 April 2005 3:36:21 AM(UTC)
Hi All
I,ve got a 5 L vt v8 with a diff problem, so instead of just fixing it i'd like to also modify it. Initially i was told to go for a 9" ford diff, but as i don't ave $5,000 to spare at the moment i've decided to rebuild z same diff but change the ratios. At the moment it has the original 3.08 diff, i was told to change this to 3.45 (same as the hsv). Can anyone help me with this problem ? What do u guys recommend.
RussVRute Offline
#2 Posted : Sunday, 10 April 2005 6:17:30 AM(UTC)
RussVRute
sorry I cant help you with your problem, but wile on the subject of diff ratios,you might be able to help me, I would like to know how to find out what my diff ratio actually is, I presume you jack the car up and turn the tailshaft one revolution and coun
666 Offline
#3 Posted : Sunday, 10 April 2005 10:37:50 AM(UTC)
666
Holyfield,
If u want more torque and less economy yes, go for 3.45 or 3.7. 2nd hand ratios cost about $220 and new $440 - Con at Diff Technics, Miranda NSW.
RussHX,
If u can't find a Tag on yer diff, as a rough guide: jack 1 wheel up and note the posi
666
#4 Posted : Monday, 11 April 2005 9:11:07 PM(UTC)
Thanks 666, i'll call em as well as others before i start work on it. By the way has anyone seen a web site where i can find the different acceleration & fuel usage for different ratios. Or maybe if someone has put in a 3.7 diff can tell me what their fue
666 Offline
#5 Posted : Wednesday, 13 April 2005 12:49:00 PM(UTC)
666
Holyfield,
Here's another trick for judging what diff'l work for ur engine - say ur doin 100ks/h and it's revin in top gear(not over drive) at say 2000rpm. Now for every 0.1 u increase ur diff ratio by will add 100rpm to ur engine revs to maintain 100ks
666
#6 Posted : Wednesday, 13 April 2005 1:44:13 PM(UTC)
Thanks again 666, thats quite useful & supports what i've been told so far. I guess the question that remains is how much more acceleration i would get with the 3.7 compared with the 3.45 ? Is it a major difference or i couldnt tell the difference unless
666 Offline
#7 Posted : Wednesday, 13 April 2005 11:11:30 PM(UTC)
666
Acceleration is not all about ur diff but more so ur mota. Starting at the front - Dyno ur motor to find out its power curve ,then decide the purpose u want to use this motor for(Daily Driver/Street n Strip/QtrMiler Then adapt ur diff to suit ur trany (Au
666
#8 Posted : Tuesday, 19 April 2005 3:48:54 AM(UTC)
I run a 3.7, its why I put a 5 speed in the ute. If you ever travel on the highway over a couple of hours or like to travel. Go with a 3.45 if you have a 4speed.
Run Sydeny to Bris etc you could swear you have been to a metal concert.
Gav
#9 Posted : Tuesday, 19 April 2005 6:40:52 AM(UTC)
Thanks Gav
I've already got a 5 speed in it. What did u ave in yours b4 the 3.7. Did u get much increase in acceleration, and lose much speed/power at the top end. How about fuel consumption major difference ?
At the moment im also considering conve
crowe Offline
#10 Posted : Tuesday, 19 April 2005 10:12:39 PM(UTC)
crowe
Have a look at the flange behind the un joint sometimes its stampted there
This page was generated in 0.124 seconds.
