#1 Posted : Wednesday, 13 April 2005 5:49:09 AM(UTC)
hi guys, just browsing ebay and saw a 308HP block. I've heard of 149(?) & 179HP's with the steel crank, but My Q is, what cars were HP blocks fitted to, and what's so special about them?
70ute
68sedan
#2 Posted : Wednesday, 13 April 2005 6:34:21 AM(UTC)
Short answer...nothing is special about them. AFAIK, they are just an early 308 block.
Cheers...Dave
#3 Posted : Wednesday, 13 April 2005 6:52:44 AM(UTC)
HiGuys.
Same as 179HP, nothing special about them either.
Dr Terry.
#4 Posted : Wednesday, 13 April 2005 7:13:44 PM(UTC)
Fitted to early HT's, mainly Broughams as the 308 was initially only available on the Brougham. When someone some day figures outwhat HP means on the 179, we will at least have a clue as the why it is on the 308.
#5 Posted : Thursday, 14 April 2005 3:33:13 AM(UTC)
Hi Guys.
Speaking to people who worked in the Holden engine plant in the 60's, there are various versions of events.
The most common of these is that 'HP' meant high performance. The 149 block had no casting number in that spot & the 179 had HP, me
#6 Posted : Thursday, 14 April 2005 6:52:20 AM(UTC)
That is something I never knew, ie the very early 253 was blank. I always thought it said 253, and it didn't make sense that they would have 253 and HP, so what you say now makes sense. The only thing that doesn't seem right though is the 179
witcheshollow racing team Offline
#7 Posted : Thursday, 14 April 2005 9:16:33 AM(UTC)
That is of intrest, I thought they always had 253 or 308 cast on the side as well. So, from what I can gather from this the 308 HP block was from the 60's early 70's holdens ? This would make finding on in a HZ a little unusual ? This would mean a HT bloc
"Such is life"
#8 Posted : Thursday, 14 April 2005 6:36:17 PM(UTC)
Unless it was a factory manual HZ Premier a HP block would have been useless as they were all Trimatic pattern, and you couldn't easily change the bolt pattern on the early blocks. There is no way that a HP block was factory in a HZ. From what I have seen
#9 Posted : Thursday, 14 April 2005 10:34:02 PM(UTC)
Looking at that block & getting the casting number & prefix may help determine it's true identity. I agree with everything Byron & Terry have noted.
There are certainly some oddball ones around though, I but have been told by a reliable sydney wrecker h
#10 Posted : Thursday, 14 April 2005 11:06:48 PM(UTC)
The NT is simply a Nasco replacement short motor for a stock 308 for HQ to whenever the practice stopped. The actual numerals off the engine number will tell you when it was made, as will the casting date. I seriously doubt that the NT block you are refer
#11 Posted : Friday, 15 April 2005 3:35:24 AM(UTC)
Isn't that an 'HZ' prefix for an L34.
Dr Terry.
#12 Posted : Friday, 15 April 2005 4:03:43 AM(UTC)
Not for a Nasco replacement short motor.
I just read one of my posts above, and it reads like I was suggesting that your pride be shattered. It's poorly written. I meant the dude who had the HZ with the HP block.
Byron
Edited by user Friday, 15 April 2005 4:07:17 AM(UTC)  | Reason: Not specified
#13 Posted : Tuesday, 19 April 2005 5:31:34 PM(UTC)
Just a little side story whilst discussing engine block numbers. A friend of mine had a HT 253 Monaro many years ago and on the side of the block where the block size is cast, it had 186 instead of 253. Figure that one out.
#14 Posted : Friday, 15 July 2005 9:14:51 PM(UTC)
is there any way to confirm iff i have a l34 308 engine my serial number is11qt731068 regards lohn
#15 Posted : Friday, 15 July 2005 9:37:21 PM(UTC)
That's a Statesman engine. L34 engine numbers start with HZ, or NZ for a Nasco or GMP&A replacement short motor. I can't remember what series the 73 number came out of (Warren will know), but it's most likely also a HJ-HZ block which means it will be a T
#16 Posted : Friday, 15 July 2005 9:58:20 PM(UTC)
[quote]Originally posted by john georgiou
[/quote$6000.00
#17 Posted : Saturday, 16 July 2005 1:45:02 AM(UTC)
L34 engine nummber would start HZ or NZ. 11QT is a statesman 308 from HQ to HZ. engine number would indicate HX era.
Warren
This page was generated in 0.100 seconds.
