#1 Posted : Wednesday, 13 April 2005 7:18:33 AM(UTC)
I recently received crook fuel from a popular supermarket outlet and the car in't running properly. I've been told by a Ford dealer that I would need to have the injectors cleaned etc. I changed the filter and this has made no difference. Thoughts?
#2 Posted : Wednesday, 13 April 2005 7:24:01 AM(UTC)
try the old Metho in the fuel tank trick, the metho picks up the water and helps run it through the system or a few bottles of Injector Cleaner and 98 octain fuel
#3 Posted : Wednesday, 13 April 2005 11:13:24 AM(UTC)
Try Spitfire or one of the Nulon injector cleaners. There is also another product called fuel doctor that you can get from super cheap. Not sure how well that one works though it does make a lot of claims.
#4 Posted : Wednesday, 13 April 2005 6:59:25 PM(UTC)
injectors need to be seviced every 100,000 km if left over time they can run bad and give poor ecconomy.just a thought.
#5 Posted : Tuesday, 17 May 2005 10:22:31 PM(UTC)
FUEl DOCTOR is the tool of trade for FUEL DOCTORS AUSTRALIA, a fuel tank cleaning company that cleans underground fuel tanks in service stations,truck stops and marinas,Including all manor of chassis and boat tanks,the claims made of the product are the p
#6 Posted : Thursday, 19 May 2005 9:46:30 AM(UTC)
Might be the cheap fuel that you are buying from Supermarkets. Most of their supplies is supposedly imported from Indonesia and has a higher sulphur content and more impurities.
You get what you pay for.
Kind regards
George
#7 Posted : Friday, 20 May 2005 9:24:31 PM(UTC)
George,there is a national standard for fuel. Refined petrol from Asia must adhere to that standard and is sampled prior to loading to prevent refusal on arrival in Australia.The majority of operational problems for fuel pumps and Injectors results from s
#8 Posted : Saturday, 21 May 2005 6:24:52 AM(UTC)
I got a tank full of sludge from a petrol depot which was ipossible to drain. It ruined two ford gauge filter assembleys.I had to remove the tank, remove the gauge, tip out contents then sponge it out, put in clean fuel swirl around then sponge out again
