#1 Posted : Thursday, 21 April 2005 9:38:45 AM(UTC)
hey every 1
im going to up grade me suspention
on my 1 tonner need better handling
back going to be droped a bit but my main
consurn is wat type of setup is good for my front end
witch will be lowered to even the car out as well.
im after not a cheap or expencive set up something in between
just so it dont feel like ur driving a boat.
any sajestions
#2 Posted : Thursday, 21 April 2005 11:03:19 PM(UTC)
OK ! Remember you must watch how much you drop it, and how wide ur tyres are. There is a compromise. How are ur front suspension rubbers ? There's about $400 in parts there for starters. Remember its a ute, not an L34 Torana. I would recommend u chat to P
#3 Posted : Friday, 22 April 2005 5:09:39 AM(UTC)
an rts chassis would be a good start if you have non rts hq/j (?) a couple of 2" drop spidles ($6-700?) from crs will lower it without changing any steering/bounce geometry, may want HD springs though.
straight lowered springs shouldn't cost much more th
Taz2 Offline
#4 Posted : Friday, 22 April 2005 5:00:44 PM(UTC)
Taz2
For HQ sedans....(same could apply to utes)
Changeover control arms from Pedders (simpler than pressing your own rubbers in & out).
Nolethane bushings in the upper control arms only. Original rubbber bushings in lower arms....nolethane makes the ride to
In thrust we trust
RussVRute Offline
#5 Posted : Friday, 22 April 2005 6:23:31 PM(UTC)
RussVRute
G'day All,
While on that subject, is it easy to put rear sway bars on a 1 Tonner? I was thinking of doing it to mine and saw this topic so I thought I would chip in. In fact I dont think the HX has them on the front either are they easy to fit as well?
#6 Posted : Friday, 22 April 2005 8:50:45 PM(UTC)
My HZ tonner has the fully rebuilt factory RTS setup and it handles fantastic however we had to remove the factory rear sway bar to fit the gas tank but i honestly don't think it has made much difference.I've had several people comment on the way it handl
#7 Posted : Friday, 22 April 2005 9:54:17 PM(UTC)
Before you start spending any money on it get someone that knows where to look have a look for the 'factory' cracks in HQ-WB chassis (1-tonner especially). If it's not cracked fit the WB strengthening bars - these minimise cracking. If it's mildly cracked
#8 Posted : Saturday, 23 April 2005 3:35:18 AM(UTC)
thanks every 1 for that information
Byron good idear about getting my car checked..
i a bit worried tho, when i get to that rust that might be hiding.
then again the car is 31 yrs old so its sort of expected.
What i got to think about now is how lon
Intoit Offline
#9 Posted : Saturday, 23 April 2005 3:36:50 AM(UTC)
Intoit
Have a look on the net for Tubular Suspension Systems . The guy to talk to is James Cloke . They build tubular A arms with needle roller bearings (no bushes). My mate bought a set for his HQ tonner , lowered to your spec and no more squeaky front end . Wh
--------------------Go Hard Or Go Home
#10 Posted : Saturday, 23 April 2005 8:38:08 AM(UTC)
I would be interested to see how these needle roller front arms work. Being a fitter by trade I know that for every floating bearing ( being the neddle bearing ) you have to have a fixed bearing, otherwise the upper and lower arms will have a certain amou
#11 Posted : Saturday, 23 April 2005 9:03:20 AM(UTC)
Are these tubular parts legal ? I think not in all states.
If you fit a HZ or WB chassis for the RTS you will get a far better ride and steering but you will have to upgrade to the emissions control for the chassis which will kill your performance and ec
Intoit Offline
#12 Posted : Saturday, 23 April 2005 5:32:51 PM(UTC)
Intoit
#13 Posted : Tuesday, 26 April 2005 7:32:16 AM(UTC)
Hey GTS Ton, where did you learn to spell the queens english.
Intoit Offline
#14 Posted : Wednesday, 27 April 2005 6:27:38 AM(UTC)
Intoit
Ditto ,
No comment was the stern reply !
Guest (11)
This page was generated in 0.159 seconds.
