#1 Posted : Monday, 25 April 2005 1:04:46 AM(UTC)
Hello Everyone,I have a 186 holden motor with a 3 speed mated to it but I wish to change it over to a 4 speed what 4 speed is the best to use, the motor is going in a 71 HQ ute. Using a 4 speed can I use the clutch, pressure plate and parts from the 3 speed as I like to keep the costs down.The heavest load would be me Bullterrier. Cheerio Owen.
God is Dog spelt backwards.
classic oz wreck Offline
#2 Posted : Monday, 25 April 2005 7:35:22 AM(UTC)
classic oz wreck
owen,if you use the aussie 4 speed you will only need gearbox and shifter and a hole in the floor...clutch pressure plate bellhousing etc etc etc is all the same....
www.classicozwreck.com.au
#3 Posted : Sunday, 1 May 2005 8:51:26 AM(UTC)
With an EH (converting from a crash box to an Aussie 4 speed), apart from the manual tunnel "modification", would I need a different tailshaft, bellhousing, crossmember etc., and how would the clutch hold up?. I know these are required for a Toyota Celica
#4 Posted : Monday, 2 May 2005 7:13:43 PM(UTC)
Yes to all of the mods. To get a better clutch on a red you can do two things. Either fit a 1-tonner clutch, or change the flywheel to a blue motor one and use a blue/black motor clutch. These have a bigger clutch plate.
Owen, if you would like to use
#5 Posted : Wednesday, 4 May 2005 1:54:51 AM(UTC)
Thanks Bryon,
No thanks I only needed a 4 speed and the wrecker here had one in good nick I purchased for $400 complete with a new system like the brake cylinder but it operates the clutch. Ive spent all day installing it just needs a trial run now. Im o
#6 Posted : Wednesday, 4 May 2005 2:24:51 AM(UTC)
Wish you'd have known I had it. You could have had this conversion complete with a complete 202 for $550.
#7 Posted : Wednesday, 4 May 2005 2:29:09 AM(UTC)
Thats alright the frieght to Emerald would be a killer anyway.
