#1 Posted : Wednesday, 11 May 2005 12:06:06 PM(UTC)
Im currently running a to3/4 hybrid turbo on my FJ but at around 5600 rpm the boost drops from 14 psi to around 4 it has to3 garret turbo with to4 600hp high flow wheel and front housing it use to do the same thing with the to3 front housing just wondering if anyone had any ideas
thanks
charles
#2 Posted : Wednesday, 11 May 2005 12:07:40 PM(UTC)
forgot to mention motor revs to 7200 with 4 psi
666 Offline
#3 Posted : Thursday, 2 June 2005 10:14:27 AM(UTC)
666
Charles,
U've probably got ur intake sussed, but years ago I had a prob with an F7 Volvo truck (in a fleet of 9) - It drove perfectly except as it approached the last few hundred revs -it seemd to lose a bit of it's PULL or BOOST -
In the Wshop (with n
666
#4 Posted : Wednesday, 8 June 2005 8:44:21 AM(UTC)
thanks, intake is aluminium but even with no air cleaner still has same problem and can't really tell how much boost without load as throttle needs to be fully open and motor revs to quick without load
charles
Jim Briar Hill Offline
#5 Posted : Friday, 10 June 2005 4:14:39 AM(UTC)
Jim Briar Hill
Hi Charles, What EFI unit are you using or is it a carby job.
#6 Posted : Friday, 10 June 2005 8:52:32 AM(UTC)
twin 225 Impco LPG Mixers & convertors electronic ignition with mallory Hi-fire
#7 Posted : Sunday, 19 June 2005 7:24:47 AM(UTC)
Jim Briar Hill
Sorry long time to get back to you ( forgot about it to be honest ) have you sused it out yet. Only other thought I had was if you were running cool air induction ? Cheers Jim
#8 Posted : Sunday, 19 June 2005 12:11:37 PM(UTC)
yeah small intercooler and air intake out the front behind the grill havn't had much time to play with it as i'm converting it to 5 speed manual
666 Offline
#9 Posted : Saturday, 25 June 2005 4:23:28 AM(UTC)
666
Shi t hey,
Its a little self-satisfying that 10 years outa the game
n I was on the right track. (Air Restriction)
Howd u track that 1 down Charles ?
666
Edited by user Saturday, 25 June 2005 4:26:40 AM(UTC)  | Reason: Not specified
666
Guest (6)
This page was generated in 0.066 seconds.
