#1 Posted : Monday, 23 May 2005 9:15:19 PM(UTC)
Hi all
Ive recently put an HR front end in my EH wagon
Its got kinswood spindles and brakes on it and I have fitted a dual servo master cylinder with a VH40 booster.
The brake pedal is very hard and the rear locks up easily.
Is it just a case that I have to change the rear brake cylinders?
If so what to?
Cheers for the help in advance
#2 Posted : Tuesday, 24 May 2005 7:34:11 AM(UTC)
You need to fit the HQ brake proportioning valve as per original HQ. This stops the rear from locking up It is a valve thing with about 5 brake lines going in and out of it.
#3 Posted : Tuesday, 24 May 2005 8:10:03 AM(UTC)
Actually the proportioning valve on the Q is about halfway down the body in the chassis. It has one line in and one out. The body with about 5 lines is the split braking system. You could try fitting different wheel cylinders but I don't know which, I fit
#4 Posted : Tuesday, 24 May 2005 9:00:10 AM(UTC)
It might not be a bad idea if you look through the Hoppers Stoppers web site http://www.hoppers.com.au/indexmain.html On the home page click on the FAQ section. There is a lot of information on disc brakes for early Holdens. If you can't solve the prob
#5 Posted : Tuesday, 24 May 2005 4:40:52 PM(UTC)
If you're using a HR front end , easiest is to use HR rears too
then you get the right bias. Also visit FE/FC Holden car club forum, these guys are doing these swaps all the time.
C/F
Edited by user Tuesday, 24 May 2005 4:43:42 PM(UTC)  | Reason: Not specified
#6 Posted : Tuesday, 24 May 2005 9:34:15 PM(UTC)
#7 Posted : Tuesday, 24 May 2005 11:11:06 PM(UTC)
Hey Callum
Thats why I suggested the FE/FC site , there's a "Tech" section there that will give you the correct sized cylinders , and any other mods that need to be done , I think the address is fefcholden.org.au/nsw . well worth the visit , also
#8 Posted : Wednesday, 25 May 2005 3:17:39 AM(UTC)
Hi Guys.
Yes, an EJ to HR rear end & brakes using 9/16" wheel cylinders is the way to go.
I noticed you said you are running a dual master cylinder, but a VH40 booster, does that mean you have only boosted the front disc brakes ??
If that is the
#9 Posted : Wednesday, 25 May 2005 5:43:47 AM(UTC)
Originally posted by Dr Terry
Hi Guys.
This page was generated in 0.214 seconds.
