Mr Void Offline
#1 Posted : Friday, 17 June 2005 1:03:01 AM(UTC)
Mr Void
Hi all,
I was told that the crossmember positioning in HZ/WB 1 tonners was different to that in the VK commodores & therefore the black 202 I just got (out of a VK) will need a different sump to fit in a HZ/WB 1 tonner - is this correct???
Thanks all....
___________________
Why are you reading this, you should be looking up there^^
___________________
Dylan Offline
#2 Posted : Friday, 17 June 2005 1:57:51 AM(UTC)
Dylan
yep, you will need a sump and pick up from an HQ - WB (i think LH - UC torana is the same)
#3 Posted : Friday, 17 June 2005 3:14:31 AM(UTC)
Hi Guys.
Yes, that's correct, use an HQ-WB, LH-UC sump & pick-up.
Also often forgotten, is the dipstick & tube. On the Commodore, the dipstick goes into the side of the sump. What you have to do is use the HQ-WB dipstick tube, & fit it to the Commod
#4 Posted : Friday, 17 June 2005 7:35:28 AM(UTC)
If you are fitting the injected motor you will have to bend the dipstick pipe out a bit. Also the dipstick goes in only in a certain position so make sure you have the pipe in the right way around. I had a lot of trouble stopping oil leaks around the base
#5 Posted : Saturday, 18 June 2005 5:19:11 AM(UTC)
cool, thanks heaps guys....
