GMH1975 Offline
#1 Posted : Saturday, 18 June 2005 4:39:25 PM(UTC)
GMH1975
Hi i just bought myself a mig welder and was wondering if anyone could recomend any books or websites with info on how to set it up for different types of steel etc.
I will be enroling in a TAFE course shortly but would like to learn abit befor i start the course.
Im more interested in how to tell if i am using the right amount of gas and a bit of info on welding alloys.
Not the BLOODY Kingswood
#2 Posted : Saturday, 18 June 2005 10:13:34 PM(UTC)
email me and tell me what size attachments you can receive - file is approx 10MB
Jim Briar Hill Offline
#3 Posted : Sunday, 19 June 2005 7:12:15 AM(UTC)
Jim Briar Hill
Hi GMH1975, go down to the local scrap yard and sceem as much offcut as you can and go for it. It can be a fine art to get it right and it all come from practice. The hard thing to work out is wire speed. If you got one of the cig units ditch the brass re
GMH1975 Offline
#4 Posted : Sunday, 19 June 2005 7:23:35 AM(UTC)
GMH1975
Hi Jim.
Guess what....It is a cigweld unit and yes i got the ****y reg.
will get a new one when i get the chance.
Using it gassless at the moment because the unit came with a spool of gassless wire so i will waste that just to get a feel for it.
#5 Posted : Sunday, 19 June 2005 12:19:53 PM(UTC)
I also have a cig mig welder im currently running a spare oxy reg on mine if you are going to be welding alloys you will need argon gas instead of the argoshield light that you will use for most other materials you will need a nylon liner for your mig gun
#6 Posted : Sunday, 19 June 2005 5:27:29 PM(UTC)
All i can say about the welding books is that look over them before you buy.most welding books give you ways to weave and other bad habbits,If your wire comes out in spurts,you might not have enough wire speed.but if you molting pool seems to small or too
GMH1975 Offline
#7 Posted : Wednesday, 22 June 2005 1:44:57 AM(UTC)
GMH1975
Hi and thanks for all the info guys.
Im thinking of buying one of theses regs off ebay http://cgi.ebay.com.au/w...413&item=4388872129&rd=1
Any views on if they are worth the money?
#8 Posted : Wednesday, 22 June 2005 4:59:50 AM(UTC)
Jim Briar Hill
Good unit if you know what flow rate you want as I said in my last post the cheap BOC unit has a gadge for dummies ( no pun intended ) which tells you what flow rate you need with what work you are doing. To hard to explain but if you go in and have a loo
GMH1975 Offline
#9 Posted : Wednesday, 22 June 2005 5:56:47 AM(UTC)
GMH1975
Hi Jim.
the one from boc is $110.
The part number is 105206.
Is the one you were talking about for $60 still available?
#10 Posted : Wednesday, 22 June 2005 8:07:45 AM(UTC)
Jim Briar Hill
Thats the one but forgot to say that it was on trade price, if you have a mate thats a plummer you may get a better deal than $110 as being an ex plumming store manager I used to buy them in for $37.86 wholesale but you did not hear that from me :) :) Che
GMH1975 Offline
#11 Posted : Wednesday, 22 June 2005 3:50:54 PM(UTC)
GMH1975
Was just looking at the BOc reg on thier website and took a good look at the righting on the gauges.
It shows 15 to 30 liters per min for mig welding.
So now i know the flowrate i guess i can buy any brand of reg.
Any brands to steer away from ?
Anyon
#12 Posted : Wednesday, 22 June 2005 8:12:03 PM(UTC)
Jim Briar Hill
Sorry I sould have thought of that. I could have given you the info without the squinting. Cheers Jim.
Edited by user Wednesday, 22 June 2005 8:28:46 PM(UTC)  | Reason: Not specified
#13 Posted : Thursday, 23 June 2005 1:26:23 AM(UTC)
If you don't use your mig welder too often or too much it is way more cost effective to buy the disposable cylinders because what you save on cylinder rental a year alone pays for 3 or four disposable cylinders.
This worked for me as I was only getti
#14 Posted : Thursday, 23 June 2005 1:26:23 AM(UTC)
If you dont use your mig welder too often or too much it is way more cost effective to buy the disposable cylinders because what you save on cylinder rental a year alone pays for 3 or four disposable cylinders.
This worked for me as I was only gettin
GMH1975 Offline
#15 Posted : Thursday, 23 June 2005 2:04:43 AM(UTC)
GMH1975
Jim 5.0 Where do you get the dissposable tanks and what cost would i be looking at?
Will i still need to buy a proper reg or will my gaugeless one be fine?
#16 Posted : Thursday, 23 June 2005 6:11:14 AM(UTC)
You can pick up the disposable bottles from a lot of the good tool shops that sell welders. You also see them around the swap meets occasionally too.
#17 Posted : Thursday, 23 June 2005 6:17:55 PM(UTC)
you may want to try gassless wire have been experimenting with this and seems to work well on body panels
charles
If all drivers were enthusiasts there would be less accidents.
#18 Posted : Thursday, 23 June 2005 8:02:43 PM(UTC)
i also use gasless wire a bit, although its not really gasless it has the gas impregnated into the wire, and it seems to work fine.
i did the tafe course and it was very good (its actually a module of their engineering certificate which is to your credit
#19 Posted : Thursday, 23 June 2005 8:02:43 PM(UTC)
i also use gasless wire a bit, although it's not really gasless it has the gas impregnated into the wire, and it seems to work fine.
i did the tafe course and it was very good (it's actually a module of their engineering certificate which is to your cred
#20 Posted : Thursday, 23 June 2005 11:24:22 PM(UTC)
Will
Guest (11)
