#1 Posted : Sunday, 19 June 2005 3:50:51 AM(UTC)
gday... just have a few questions.. i bought this vn commodore not going.. the guy told me that he was driving along .. come to set of traffic lights and the car stoped on him and couldnt get it going again.. now since i got it... i found that the starter motor is clickong attempt at starting and no motor response... the motor aint seized. i checked that by taken spark plug out and turning it over.. i have checked the battery and thats fine to.. i checked relays they r all good... i wanna run bypass past the neutral switch to see if it will work but dont know how to do it.. anyoine got any ideas i also thought it could be the computer.. i run a test over that by doing the flash diagnostic check and that didnt work at all.. no flashing of lights o nthe dash.. that couldbe part of the reason... please help me on this..
thank you
#2 Posted : Sunday, 19 June 2005 3:55:33 AM(UTC)
It isnt the neutral safety switch. This wont allow the starter to "click".
For a start short out the terminals on the starter motor. (very carefully) If it turns over then you may have a relay problem. But I just think that the starter motor is shag
#3 Posted : Sunday, 19 June 2005 4:00:27 AM(UTC)
yep.. the guy said he replaced the coil pack as well before it broke down... he put a vp coil into it and he also said that power steering was leaking.. i opened the bonnet and there was fluid all over the battery terminals and fuses and relays.. to short
#4 Posted : Sunday, 19 June 2005 4:41:35 AM(UTC)
lol i only payed 100$ for it and its in pretty good nick...
and sorry im dumb when it comes to new cars.. i have only worked on a mk1 and 2 for escort, volvo 145 station wagon and vb commodore.. the engine hated me in the vb went though 4 of em then got
#5 Posted : Monday, 8 May 2006 7:50:43 AM(UTC)
#6 Posted : Saturday, 13 May 2006 8:07:56 AM(UTC)
If you have a vp coil pack they only die two leads at a time, thats why they are designed that way. so car should run really rough. if you think it is the computer which it may be as the car just dying and no lights showing is one sign of the computer ***
#7 Posted : Thursday, 25 May 2006 7:12:16 PM(UTC)
yeah i got a question for sum 1 that knows what there on about um i just bought a vn comm, and it takes friggn ages to start wen its left for over 30 min the spark plugs have been replaced and that seemed to work for a lil while but its back to its old ha
#8 Posted : Friday, 26 May 2006 12:20:35 AM(UTC)
if the check engine light doesn't flash when you short the black and black/white wires on the diag plug, then the computer is dead.
as for nelson, it sounds like leaky injectors, mine did the same. was caused by a stuffed pressure reg.
when i fitted
#9 Posted : Friday, 13 October 2006 4:23:44 AM(UTC)
Having trouble getting the correct starter motor for my VP 10/92 Commodore as Holden dont have them any more, Repco has the wrong one, wreckers keep selling me a manual one. Can anyone give a suggestion as to where next.
Munromad2004 Offline
#10 Posted : Friday, 13 October 2006 4:43:26 AM(UTC)
Munromad2004
I had a car stop on me when I pulled up at a set of lights once. The timing belt suddenly decided to let go.
I was probably doing less than 20km/h when it let go and it still mabaged to bend every single valve in the engine.
A friend with an identical
#11 Posted : Friday, 13 October 2006 9:42:41 PM(UTC)
#12 Posted : Saturday, 14 October 2006 7:31:46 AM(UTC)
VN's have chains.
try Autopro or repco again, but if there starter motor doesn.t look like your old one, don't worry straight away, it could be the high torque version.....
i did the same thing, bought a brand new bosch item, from Autopro Canberra, go
