edmundo Offline
#1 Posted: : Saturday, 25 June 2005 6:53:26 PM(UTC)
edmundo
hi,
i changed my auto on my vn, which is a v6. i was told i could use a vp auto as well, which i did. fitted no probs. but my trouble is, now when i go to start the car, it maks a HIGH pitch sound, and sometimes it wont crank. I replaced the starter (bosch), and it still makes the sound. the fly wheel is still good as well.......any thoughts..could it be a different bellhousing, (vn....vp)
thanks
666 Offline
#2 Posted : Sunday, 26 June 2005 7:26:03 AM(UTC)
666
When u say "High pitched noise", do u mean "teeth grinding" ?
Did the Flex plate or Torque converter get changed?
666
666
edmundo Offline
#3 Posted : Sunday, 26 June 2005 8:46:46 AM(UTC)
edmundo
yep
torque convertor was changed as well....
Taz2 Offline
#4 Posted : Sunday, 26 June 2005 5:09:56 PM(UTC)
Taz2
Your problem is definitely in the torque converter/flexplate area.
Actually you can't necessarily just swap auto boxes either.....even if they are VN/VP.
Needs to be the same model number (4HDD, 5HDD, 7HDD etc). Some transmissions are forward compatible
Edited by user Sunday, 26 June 2005 5:14:16 PM(UTC)  | Reason: Not specified
In thrust we trust
