14 Pages123>»
#1 Posted : Monday, 27 June 2005 11:33:46 PM(UTC)
i own a holden 186s which i wish to buildup to suit drag racing and burnouts. The mods i have already done are holley 350 and extractors. What other mods can be done to get max hp without spending to much money?
#2 Posted : Tuesday, 28 June 2005 6:49:40 AM(UTC)
Throw it away and fit a V8, seriously. A 186 is a good thing for spirited street use, but for drag racing and burnout, a small stock block Chev will be cheaper and more reliable.
#3 Posted : Thursday, 30 June 2005 12:48:19 AM(UTC)
Other mods could include: Nice cam, 12 port head or yella terra head, Good valves, i would put a big carbie on it like a 450 or 500 but a 350 should do the trick, 2 1/2 exaust. but a cheaper way would be to buy a 350 chev that has already been done up.
#4 Posted : Thursday, 30 June 2005 1:45:34 AM(UTC)
There is no great benefit in fitting a 12 port head unless you are fitting triple dual chokes (or six single chokes) or a VK EFI setup or similar.
#5 Posted : Thursday, 30 June 2005 1:54:10 AM(UTC)
well what is a better head to use on a red 6
#6 Posted : Thursday, 30 June 2005 4:26:02 AM(UTC)
cant agree more with Byron Rich a good solid 8 is the only way to go. however if you prefer to stick with the 6 i prefer yella terra heads and a nice sensible cam carby set up (350's a nice size worked well for me for many years) spend the money on a goo
#7 Posted : Thursday, 30 June 2005 4:26:02 AM(UTC)
cant agree more with Byron Rich a good solid 8 is the only way to go. however if you prefer to stick with the 6 i prefer yella terra heads and a nice sensible cam carby set up (350s a nice size worked well for me for many years) spend the money on a good
#8 Posted : Thursday, 30 June 2005 7:53:37 AM(UTC)
Back to top
Jim Briar Hill Offline
#9 Posted : Thursday, 30 June 2005 9:51:27 PM(UTC)
Jim Briar Hill
As Byron has said start with the 8 but if you want to keep the six I have had good results from the Yella Terra ported heads and then going down the Turbo path but these will not be cheap. Cheers Jim.
#10 Posted : Friday, 1 July 2005 10:31:39 PM(UTC)
Unless you want to go down the turbo path with a serious
bottom end, a 202 will be a waste of money. When they are
naturally aspirated you can spend huge bucks on them for
very little hp return (i know i worked up a 202)
A much better option if yo
666 Offline
#11 Posted : Saturday, 2 July 2005 12:05:52 PM(UTC)
666
Smoken V8,
If u seriously want to do Burnouts and Drag race ur 186,
But also not spend money.
"Nothing" beats Nitrous Oxide - Dollars for Horsepower.
Naturally though, this may become a False economy when -
the crowd is trying to catch ur Con-r
666
#12 Posted : Tuesday, 5 July 2005 1:26:35 AM(UTC)
Howdy folks,
Just to save you some phone time, I found out a couple of months back that Yella Terra have stopped making their super-sweet alloy heads for older cars. They ceased production about 12-18 months ago, and have no remaining stock.
So you
#13 Posted : Tuesday, 5 July 2005 4:03:00 AM(UTC)
i think what you mean is they stopped producing the red heads, a blue/black head is a much better option anyway...
#14 Posted : Tuesday, 5 July 2005 4:17:31 AM(UTC)
666 Offline
#15 Posted : Thursday, 7 July 2005 10:34:47 AM(UTC)
666
Check BUY N sELL it LOOKS LIKE sMOKIN v8 is selln his 186 anyway.
Edited by user Friday, 16 December 2005 4:57:06 AM(UTC)  | Reason: Not specified
666
#16 Posted : Saturday, 9 July 2005 4:44:03 AM(UTC)
i found a good yella terra head with roller rockers and triple webbers worked well for me i ran a very high compresion head with a standard bottom end and i dint blow anythin and it went hard. but if you really want some hp yo need to get a nice sized cam
witcheshollow racing team Offline
#17 Posted : Sunday, 10 July 2005 7:57:57 AM(UTC)
Everyone of the comments above are all true but what I kept wondering was 1. what type of car is the 186 in ( power to weight) 2. Is it to be a street driven car or just a toy ? and 3. at the drags what group do you intend to race in ? Plus another thing
"Such is life"
#18 Posted : Thursday, 15 December 2005 11:37:07 PM(UTC)
The car is goen to be put in burnout comps in the 6 cylinder class, and at this stage only mabey dragged, im thinking about using nos.
#19 Posted : Friday, 16 December 2005 6:24:12 AM(UTC)
Would it make much of a difference if a bolt a 149 head straight on?
#20 Posted : Friday, 16 December 2005 8:08:00 AM(UTC)
It'll raise your compression to about 11.1:1...you will HAVE to run really fresh 98 Octane fuel and listen VERY carefully for pinging.
Cheers...Dave
Guest (16)
14 Pages123>»
This page was generated in 0.083 seconds.
