14 Pages«<11121314>
#241 Posted : Tuesday, 12 September 2006 2:52:26 AM(UTC)
Originally posted by gtr235
I have a 235 stroker in my LC GTR utilising the ford 221 crank. Basically as already state
#242 Posted : Tuesday, 12 September 2006 2:59:13 AM(UTC)
Hi just new to this site wondering if you can help i have a red six sitting in my shed it has hp on side of block and has a 221 crank with a 154a cam and new pistons do you know what this is and what it would be worth thanks Mark.
#243 Posted : Tuesday, 12 September 2006 5:02:59 AM(UTC)
Its basically as per the quoted post above yours. The block is just a 179 block out of an EH. If you are to rebuild it and the block is already bored out to 3.625" + 0.055" just use all of the insides in a 186 block (with rod clearance reliefs added as re
#244 Posted : Tuesday, 12 September 2006 5:02:59 AM(UTC)
It's basically as per the quoted post above yours. The block is just a 179 block out of an EH. If you are to rebuild it and the block is already bored out to 3.625" + 0.055" just use all of the insides in a 186 block (with rod clearance reliefs added as r
#245 Posted : Wednesday, 13 September 2006 8:18:29 AM(UTC)
G'day just stumbled across the site looking for tips on how to utilise a blow off
valve on my draw through turbo 186 if it's at all possible i can't find any info on any of the jap sites for obvious reasons and everyone who is supposed to be in the kno
#246 Posted : Wednesday, 13 September 2006 8:18:29 AM(UTC)
Gday just stumbled across the site looking for tips on how to utilise a blow off
valve on my draw through turbo 186 if its at all possible i cant find any info on any of the jap sites for obvious reasons and everyone who is supposed to be in the know d
CherryBomb Offline
#247 Posted : Wednesday, 13 September 2006 8:28:58 AM(UTC)
CherryBomb
You dont want to just weld on a Bung and use a Quality aftermarket BOV?
Tho Pricy the better ones will be adjustable.
Dan
Never stop being inspired,
#248 Posted : Wednesday, 13 September 2006 8:45:41 AM(UTC)
The problem i realy have is that in other applications ie: EFI, the BOV is mounted between the compressor and the throttle body where pressure is created when the throttle is shut but in the application I'm trying to run the void between the carbies and t
#249 Posted : Wednesday, 13 September 2006 8:45:41 AM(UTC)
The problem i realy have is that in other applications ie: EFI, the BOV is mounted between the compressor and the throttle body where pressure is created when the throttle is shut but in the application Im trying to run the void between the carbies and th
#250 Posted : Wednesday, 13 September 2006 9:01:10 AM(UTC)
hey mark, are you looking to sell your 235 stroker?
CherryBomb Offline
#251 Posted : Wednesday, 13 September 2006 9:15:34 AM(UTC)
CherryBomb
Hmm, Ok. First a little correction. Wich may get you on your way. The Blow off valves are located inbetween the Compressor wheel and the Intake manifold/s. Not inbetween the throttle bodies/carbs.
The sole purpose of the BOV is to releive the pressure
CherryBomb Offline
#252 Posted : Wednesday, 13 September 2006 9:20:12 AM(UTC)
CherryBomb
Oh, and in EFI app's. The theory is the same. Just because the TB is just before the Manifolds makes no diffirence.
Dan
CherryBomb Offline
#253 Posted : Wednesday, 13 September 2006 9:20:12 AM(UTC)
CherryBomb
Oh, and in EFI apps. The theory is the same. Just because the TB is just before the Manifolds makes no diffirence.
Dan
vute Offline
#254 Posted : Friday, 15 September 2006 1:45:49 PM(UTC)
vute
vute Offline
#255 Posted : Monday, 18 September 2006 11:20:15 PM(UTC)
vute
Hi there yes it is for sale but i dont know what it is worth it is a short block with 221 crank 154a cam i think it is all new internals the pistons are new dont know what brand of parts have been used
Edited by user Saturday, 28 October 2006 5:17:22 PM(UTC)  | Reason: Not specified
barnsey Offline
#256 Posted : Tuesday, 12 December 2006 7:55:27 AM(UTC)
barnsey
Hi guys I found this link, not sure if its been posted before but it has some usefull infomation in it
cheers barnsey
p.s its a link to all the holden six motor prefexes, its got nothing to do with mr bean. lol
http://users.mrbean.net.au/~rover/choosin
Edited by user Tuesday, 12 December 2006 8:04:34 AM(UTC)  | Reason: Not specified
vute Offline
#257 Posted : Thursday, 1 February 2007 12:02:33 PM(UTC)
vute
Hi there its been a while the block i have has pistons stamped 2262p std you helped me last quote do you know what cubic inchs it would have thanks Mark.Its a 179 hp with a 221 crank with a wade cam 154a for compitition use.
Edited by user Thursday, 1 February 2007 12:10:03 PM(UTC)  | Reason: Not specified
tony_vc Offline
#258 Posted : Sunday, 3 June 2007 2:56:51 AM(UTC)
tony_vc
hey guys, my names tony and i no jack **** bout engines but ive got a vc wagon..202 and took it for a drive and it was gutless ...will a 350 carby improve it by heaps or like what other tings can i do for kinda cheap
thanks
tony (victoria)
Rock_Lobster Offline
#259 Posted : Sunday, 3 June 2007 9:15:00 AM(UTC)
Rock_Lobster
Tony-VC
Download and read the Street Machine Grunt Hunt article.
http://carpoint.ninemsn....alias=carpointau&id=7229
The cheapest thing is to mod your air filter housing. A housing that
only has a "top" lid, with t
tony_vc Offline
#260 Posted : Sunday, 3 June 2007 9:28:42 PM(UTC)
tony_vc
alright thanks heaps that should help
Guest (11)
14 Pages«<11121314>
This page was generated in 0.083 seconds.
