#1 Posted : Thursday, 7 July 2005 5:48:12 AM(UTC)
I want to convert an existing 4drum no power assist braked HG to 4 wheel discs. Happy to chage wheel patterns to other than HKTG if necessary, but want all 4 wheels identical.
Your suggestions and advice will be appreciated>.
#2 Posted : Thursday, 7 July 2005 6:25:43 AM(UTC)
Not sure if you've been there, but Hoppers offers lots of info on their site:
http://www.hoppers.com.au/
#3 Posted : Thursday, 7 July 2005 8:09:27 AM(UTC)
volvo diffs are a close fit and all come with disc brakes and if you have a balljoint front end it isnt hard to make caliper adapters to fit volvo 4 spot calipers on the front and you even keep your standard bolt pattern.
hope the info helps
char
#4 Posted : Friday, 8 July 2005 2:32:01 AM(UTC)
Short but sweet (and basic) spiel:
Fit a complete VL turbo/V8 diff.
Get new blank HQ-WB front discs and drill them to Commodore pattern (or order as such).
Fit the HQ discs and HQ-WB calipers (best are HZ Girlock).
Get a HK-HG disc brake booster and
Mr Void Offline
#5 Posted : Friday, 8 July 2005 11:23:57 PM(UTC)
Mr Void
just remember that the 1" master cylinders were only on the V8 VB-VR's.
___________________
Why are you reading this, you should be looking up there^^
___________________
