I want to convert an existing 4drum no power assist braked HG to 4 wheel discs. Happy to chage wheel patterns to other than HKTG if necessary, but want all 4 wheels identical. Your suggestions and advice will be appreciated>.
Not sure if you've been there, but Hoppers offers lots of info on their site: http://www.hoppers.com.au/
volvo diffs are a close fit and all come with disc brakes and if you have a balljoint front end it isnt hard to make caliper adapters to fit volvo 4 spot calipers on the front and you even keep your standard bolt pattern. hope the info helps char
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
Short but sweet (and basic) spiel:
Fit a complete VL turbo/V8 diff. Get new blank HQ-WB front discs and drill them to Commodore pattern (or order as such). Fit the HQ discs and HQ-WB calipers (best are HZ Girlock). Get a HK-HG disc brake booster and |
just remember that the 1" master cylinders were only on the V8 VB-VR's.
___________________ Why are you reading this, you should be looking up there^^ |
___________________ - HJ turbotonner looks and goes like a sneezing rhino on heat! - |
