#1 Posted : Saturday, 23 July 2005 8:37:43 PM(UTC)
I have an '88 XF ute that I put a second hand 4.1 (carburettored) motor in 12 months ago. Compression tested at that time and was good. In the last few months it has developed an annoying problem where it can be started with no problems (hot or cold) and will happily idle at normal revs for 5 minutes or so. It then seems to drop revs and cough and eventually stall. It has no dramas starting again but won't idle. If it is manually revved it will prevent stalling and after a few minutes of revving will usually come good. If it is driven within 5 minutes of starting, it will stall at intersections etc. I know it need valve stem seals as it blows smoke after it has stopped at an itersection and smells a bit fumey sometimes. Funnily enough, the previous motor had similar symptoms and ended up dropping a ring. Oil consumption seems normal, slight usage of coolant with no obvious source.. Please help...
#2 Posted : Sunday, 24 July 2005 6:36:09 PM(UTC)
might be a carb problem?id look to see if the choke is working properly,when its been sitting overnight take the top off the aircleaner and it should be closed,when the motor is hot take it off again and see if its fully opened.also these carbs have the p
#3 Posted : Tuesday, 26 July 2005 2:57:30 AM(UTC)
I have a similar problem with my '85 XF wagon, however, I have the 4L EFi engine with the auto trans running on ULeaded fuel with valve saver. The problem arises once again when the engine is cold, and although the engine idles fine when started, once it
#4 Posted : Tuesday, 26 July 2005 6:20:01 PM(UTC)
the efi engine doesnt have a choke like the carb motor.not sure about the efi i might be able to think/find something.
#5 Posted : Thursday, 11 August 2005 3:57:29 AM(UTC)
i am having similar problems with my 87 xf s pac sedan when u first start it choke gos on 4 10seconds an d then cuts out and stalls and also stalls once its in reverse and it lurches up slight hills mechanics stumped me stumped
#6 Posted : Thursday, 25 August 2005 8:06:29 PM(UTC)
Howdy,
It's worth checking the 'Fuel cut-off Solenoid' which screws into the side of the Carburettor (In an XE/XF anyway) If your Model
has this (there's no such animal as a 1988 XF Falcon) get back to me and I'll explain how you can Test to see if it's
#7 Posted : Friday, 26 August 2005 7:32:10 AM(UTC)
i think xf utes were made with 4.1 motors till around 92.
#8 Posted : Tuesday, 27 September 2005 9:47:33 PM(UTC)
Just an update on my last message, an EFi specialist checked over my engine and it seems all the problem was that the air-flow meter was out of adjustment.
Thought I'd post this in case anyone was interested.
#9 Posted : Wednesday, 28 September 2005 6:52:31 AM(UTC)
a friend has the same prob,do you know what he done?
ZC-Cruiser Offline
#10 Posted : Wednesday, 28 September 2005 10:48:22 PM(UTC)
ZC-Cruiser
It may be a faulty Power Valve diaphragm - Father-In-Law tells me that this will cause the problem you have
Get a carby kit and replace all the gaskets and give the whole thing a good clean out...
It's good to honk in a Henry
#11 Posted : Sunday, 9 October 2005 11:33:11 PM(UTC)
my xf ute is a 85 model with a recon motor out of sedan same model and it idling high is there any quick solution for this
#12 Posted : Wednesday, 19 October 2005 5:50:06 PM(UTC)
I have a problem with idle on a 4.1 engine with 34adm carby, have put a new kit through it and made no difference. It will run only if I cover the secoundary barrel. I have also replaced the fuel solonoid and it sounds to be working.
Cheer's
#13 Posted : Thursday, 3 November 2005 12:32:17 AM(UTC)
i think you all should check you fule volume and timming then make sure the carb and injectors are full function there ant much to those old motors
Guest (6)
