Dylan Offline
#1 Posted : Monday, 25 July 2005 5:50:31 AM(UTC)
Dylan
just put my new engine in and need to know how the ignition is wired.
where do the green and pink wires (from dizzy) go and where does the ignition wire go to? i have wired in a relay from the orginal HQ ignition wire to provide a full 12 volts.
i think i have the green going to the positive side of coil aswell as ignition wire, and pink to negative. thats the way it was when i got it and it did run in the old car. now i have no spark. am i missing any other wires?
RussVRute Offline
#2 Posted : Monday, 25 July 2005 7:09:01 AM(UTC)
RussVRute
G'day Dylan,
You have them the wrong way around, the pink goes to Positive and so does the black wire from the condensor, and also the main ignition wire, the only thing that goes to the negative is the Green wire. Hope this helps, and I also hope and pr
Dylan Offline
#3 Posted : Monday, 25 July 2005 7:17:09 AM(UTC)
Dylan
thanks mate, the pink and black wires (i thought it was a noise supressor, go to the same post on the coil so that must be the pos,i'll giv it a shot
RussVRute Offline
#4 Posted : Monday, 25 July 2005 7:29:05 AM(UTC)
RussVRute
Dylan Offline
#5 Posted : Monday, 25 July 2005 8:05:28 AM(UTC)
Dylan
i think its stuffed, i swaped the ignition wire over, still no go. looks like i will be pulling the dizzy out this week.
Taz2 Offline
#6 Posted : Monday, 25 July 2005 3:03:52 PM(UTC)
Taz2
Are you sure the relay is okay?
Try running without it.....I know you won't get the full voltage, but at least you'll be able to ascertain if the relay or wiring is okay, and you should at least get a spark.
In thrust we trust
Munromad2004 Offline
#7 Posted : Monday, 25 July 2005 11:34:10 PM(UTC)
Munromad2004
Rather than relying on the colours of the wires, grab yourself a wiring diagram and use that to verify you have the correct wires. Most decent maintenancer manuals will have one.
Follow the circuit and then test that you have the correct wires.
Doi
Dylan Offline
#8 Posted : Tuesday, 26 July 2005 2:52:29 AM(UTC)
Dylan
i tested the wiring with the test light, the wire going into the relay is live when the ignition is on and while cranking, there is no problems there.
what sort of grease do i need to use on the ignition module when i replace it?
Edited by user Tuesday, 26 July 2005 2:55:54 AM(UTC)  | Reason: Not specified
trubluhq Offline
#9 Posted : Tuesday, 26 July 2005 3:27:21 AM(UTC)
trubluhq
If using HQ wiring the pink is used with the engine idling. The pink wire has an inbuilt balance resistance in it. The yellow cable is used in the cranking mode. Both pink and yellow join at the bulkhead and come out in yellow only for the dizzy.
Rgds
Dylan Offline
#10 Posted : Thursday, 28 July 2005 3:20:28 AM(UTC)
Dylan
turned out to be the leads, they wernt pushing onto the spark plugs. fired easily today after changing the leads and chraging the battery.
Guest (6)
