#1 Posted : Friday, 29 July 2005 1:45:45 AM(UTC)
hi, ive got an xc falcon sedan with an xe 250 crossflow engine, im just looking for advice on making it go faster and what sort of upgrades can be done to a 250, im only a young guy and i dont know a whole lot about cars YET, but im really keen to get this project going, any feedback or advice would be great
ZC-Cruiser Offline
#2 Posted : Friday, 29 July 2005 5:58:37 PM(UTC)
ZC-Cruiser
Find an XF with an EFI engine and swap that in to start with.
Alloy head to save weight and those EFI engines make 170hp stock.
The later XFs with the indicators in the front bumper are designed to run on Unleaded, so keep a lookout for one of those
It's good to honk in a Henry
#3 Posted : Thursday, 4 August 2005 7:22:18 AM(UTC)
G'day mate i would get a secondhand EFI head off an XF 1986 EFI but make sure it is a E2 head. and shave that about 35thou. these heads are open chamber heads and out flow the stock carby heads. extractors 2.5" exhaust.
Edited by user Thursday, 4 August 2005 7:23:25 AM(UTC)  | Reason: Not specified
#4 Posted : Thursday, 4 August 2005 10:21:47 PM(UTC)
yer an xf EFI with some extractors and 2.25 or 2.5 inch exhaust. the stock EFI motor will go pretty good, better than your XE 250. the wiring for the EFI isnt 2 difficult to put in.the computer and loom shouldnt be to hard 2 fit in, an EFI XF donnor car
#5 Posted : Saturday, 6 August 2005 4:49:03 AM(UTC)
So, i should find an e2 efi xf head and but that on my existing block? will that work, or do i need to change the entire engine? I was talking to the guy i got the car off and he told me that if i was going to put an efi in, to go with a 4 litre???
#6 Posted : Saturday, 6 August 2005 4:54:55 AM(UTC)
why are you sticking to a 6 drop a 302 clevo in
#7 Posted : Tuesday, 9 August 2005 5:27:27 AM(UTC)
you can swap any alloy head (2) onto ur block, the only thing is the compression ratio,it's a leaded engine and if u put the E2 head on the comp will drop and you will have less power, thats y you need 2 mill something off it, then the comp will be more,
#8 Posted : Monday, 4 September 2006 12:24:58 AM(UTC)
i wound like to know the tenions of rocker bolts and lifter or are they self ajusting
#9 Posted : Wednesday, 1 August 2007 9:50:57 AM(UTC)
hey im onli 16 but i already rebuilt my 1985 xf 250 cross it wasnt that hard even tho i no hardly anything but the rocker bolts and lifter are self ajusting but i have a problem now i put it all back together it runs for about 4 minutes then starts to spl
#10 Posted : Thursday, 9 August 2007 4:59:44 PM(UTC)
#11 Posted : Wednesday, 16 January 2008 12:32:26 AM(UTC)
You need to make sure the (yellow?) wire is connected to the automatic choke, otherwise this will stop it from 'turning off' or opening up the butterfly.
v8fordrx7 Offline
#12 Posted : Wednesday, 16 January 2008 9:35:19 AM(UTC)
v8fordrx7
Hey all,xc iron head,bolt 350 holley and manifold on,extracters and 2 1/2 system for mild poke,xf injected engine with same above (computers suk lol),u will need to fit electric fuel pump as injected doesnt have pump lobe,injected cam is same as fitting m
v8fordrx7 Offline
#13 Posted : Wednesday, 16 January 2008 9:38:38 AM(UTC)
v8fordrx7
almost fergot,throw choke away lol,you get slightly better airflow anyway,just need to warm the car up better when you first start it,you should give it warm up time anyway before you drive it.:p
Guest (10)
