#1 Posted : Tuesday, 2 August 2005 2:57:46 AM(UTC)
heads have check out ok ,engine runs well but after running a while on restart it hydrolocks and water comes out of pcv valve,pistons and bores look ok
#2 Posted : Tuesday, 2 August 2005 4:58:12 AM(UTC)
Valley cover leaking into Inlet tract due to corrosion or warped mainfold/head face is the only reason that I can think of (except a porous block but I've never heard of that problem in a Holden motor.
Cheers...Dave
#3 Posted : Friday, 5 August 2005 10:58:02 AM(UTC)
Water cooled exhaust manifold has a hole in it?
#4 Posted : Friday, 5 August 2005 11:03:06 AM(UTC)
Use the black silicon when sealing up your intake manifold. Nothing beats it. If it has been faced before then sometimes you might need to use 2 sets of gaskets. A couple of the front bolts on the manifold actualy sit in the water gallery. There is a spec
