#1 Posted : Monday, 8 August 2005 4:39:13 AM(UTC)
I have an fc and am looking to put a vn diff into it. i have just finished putting a 186 into it with similar specs to an xu1. i also have a supra five speed behind it. i have been told that i should be looking at higher ratios than the standard 3.08 because of the gearbox. i was just wondering if anything like sss or utes came out with 3.5's or higher as standard.
#2 Posted : Monday, 8 August 2005 5:32:21 PM(UTC)
The VN used a Borg Warner (or BTR) 78 series diff, as did all commodores from VL onwards up to VT series 1, and later build VK 6s.
These were also used in Falcons, Skylines, and Pintaras of the era.
You can get the following ratios (and more):
3.08
#3 Posted : Wednesday, 10 August 2005 6:38:22 AM(UTC)
thanks heaps for your info
#4 Posted : Wednesday, 10 August 2005 7:11:47 AM(UTC)
just wondering though, i read a previous article which someone said about spline differences. if this is the case, is it not a simple pull out put in changeover for centres. also is there any identification stamps, etc. to tell the difference?
#5 Posted : Wednesday, 10 August 2005 7:21:24 AM(UTC)
The spline difference is for VL LSD and open centre.
LSD and later diffs use 28 splines, while VL open centre use 25 splines.
If you already have the diff, then changing the ratio is only a matter of swapping the pinion & crownwheel, and will have n
#6 Posted : Friday, 3 March 2006 5:24:24 AM(UTC)
#7 Posted : Friday, 3 March 2006 5:25:37 AM(UTC)
any one know if the VN S pac has a LSD Diff Or not
#8 Posted : Friday, 3 March 2006 7:26:58 AM(UTC)
VN S had LSD as an extra cost option.
#9 Posted : Wednesday, 9 May 2007 11:49:56 PM(UTC)
ring v6 conversions (0267511243) and ask about the diff conversions im sure they can put the vn diff into a fc
#10 Posted : Thursday, 10 May 2007 12:51:41 AM(UTC)
Why not just put a HR banjo rear in (they bolt straight in) with either:
3.90
3.55
3.36
3.08
or
2.78
These are readily available and if you want you can go fine spline (same as late LJ XU1) by picking up an HX to WB centre, not sure if LX also
#11 Posted : Thursday, 10 May 2007 12:54:03 AM(UTC)
Also I think the 3.55:1 bolts straight inot the FC housing.
Warren
#12 Posted : Thursday, 10 May 2007 5:50:20 AM(UTC)
I agree with Warren. If you must go stronger, ive heard early Volvo diffs are the same width and same stud pattern, and strong.
Edited by user Thursday, 10 May 2007 5:56:52 AM(UTC)  | Reason: Not specified
#13 Posted: : Thursday, 10 May 2007 5:50:20 AM(UTC)
I agree with Warren. If you must go stronger, i've heard early Volvo diffs are the same width and same stud pattern, and strong.
#14 Posted : Monday, 14 January 2008 1:13:18 AM(UTC)
i am searching for a 300 pound spring kit for bw 78 can anyone give me an idea of where i can get them from and how much cheers
bundybluedog Offline
#15 Posted : Monday, 14 January 2008 10:49:40 AM(UTC)
bundybluedog
Commodorenut, Did all 5ltr commodores with manual come with LSD or was it an extra option?
#16 Posted : Friday, 29 February 2008 6:27:46 AM(UTC)
hey guys i was wondering i have an r31 silowhett and i wana put a manual gearbox in and an LSD diff wat can i do, and if possible wat is the cheapest way
#17 Posted : Friday, 29 February 2008 9:01:15 AM(UTC)
Not all manual 5L got LSD - it was still optional.
As far as the R31, grab yourself an LSD centre from a BW78. As far as the box, you'd be best off finding another manual one & swapping bits. Or try one of the aussie skyline forums.
Mic
#18 Posted : Friday, 29 February 2008 9:01:15 AM(UTC)
As far as the R31, grab yourself an LSD centre from a BW78. As far as the box, youd be best off finding another manual one & swapping bits. Or try one of the aussie skyline forums.
#19 Posted : Thursday, 5 February 2009 1:22:14 AM(UTC)
changing centre in vn v6 diff chasing up 3.89/ 4.11 from a pintara do the earlier skylines hav any other ratios similar to those?
#20 Posted : Thursday, 5 February 2009 1:41:21 AM(UTC)
i have 3.36 3.55 banjo diff centres all have backlash in the caseing so finding a decent one might be hard as they dont sell new parts for them
Guest (14)
This page was generated in 0.098 seconds.
