2 Pages<12
#21 Posted : Monday, 5 September 2005 10:24:57 PM(UTC)
Les had another email come through to me asking the following
"hey, i read on the forum that you were thinking of getting some quarter panel rust repair sections for the Mk1 capris. So i was just wondering if you had any in, or if you know anywhere tha
Munromad2004 Offline
#22 Posted : Monday, 5 September 2005 11:04:11 PM(UTC)
Munromad2004
Hi Insaen,
Coupe honeycombs were plastic and were flat on the back.
regards
Darren
Paul351xb Offline
#23 Posted : Tuesday, 6 September 2005 1:54:43 PM(UTC)
Paul351xb
Honeycombs were also 2 piece, they had metal threads imbedded in the plastic which were held on to the car by nuts through holes drilled into the boot. Available only of GTs and Fairmonts in XA and XB. I'm not sure if the XC had honeycombs on the Fairmo
#24 Posted : Tuesday, 13 September 2005 4:34:08 AM(UTC)
XA Coupe Tail lights, left and right are identical which should be cheaper to tool up. I have a couple of decent ones if you want to borrow/buy for measurments.
Mal.
XA Fairmont GS coupe
#25 Posted : Tuesday, 13 September 2005 5:01:16 AM(UTC)
i've owned three coupes 2 XA and one XB and all had plastic lugs at the back of the honeycomb strips which are attached to the car with pressed steel nuts that seem to break the plastic lugs easily, i've never come across them with metal threads imbedded
#26 Posted : Friday, 16 September 2005 11:01:00 PM(UTC)
P5 Ltd/Landau Tail lights & decor panel Lenses & front and rear side lenses are on my wish list. Also wheel arch moulds. Does anyone know if fairmont sedan or GXL rear moulds are the same as the hardtop?
#27 Posted : Saturday, 17 September 2005 2:57:47 AM(UTC)
Munromad2004
Hi Kenk,
Sedan wheel arch trims are definitely not the same as Coupe one.
Also, there were differences in the thickness of the trims from XA/XB to XC (wider)
I also believe that the Luxury models has a different style of trim again.
Coupe rear
#28 Posted : Saturday, 17 September 2005 5:14:55 AM(UTC)
the fixed rear side window rubbers for a xy/xw wagon are imposibile to get you can get every other rubber for the wagon but these 2 makes life hard if there is rust in the window frame and the window has to come out.
Built-it Performance V8 Car Club
w
#29 Posted : Wednesday, 8 February 2006 7:49:26 PM(UTC)
Originally posted by les
The quantity of Capri’s is a problem in it’s self, we do make lower guard section for them a
Guest (12)
2 Pages<12
