hello all i was just thinking on some ideas on a 202 prepolution build for my hq and was wondering if a 265 crank out of a hemi 6 could be made to fit into a 202 block and if so what would be the benifits i've heard of fitting a ford crank though
also if this could be done what options do i have for rods, pistons and cam
thanks in advance.
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
265 won't fit - too long. A Ford 221 can be made to fit, but these need a cut and shut with an early red 6 rear flange. Pro-stroke in WA do them. Will cost you a lot though. You probably are heaps better of $ wise buying a wrecked VN for $500, and getting |
what if u were to cut and shut a 265 or 245 or even 215 crank ??
The bore centres are too different for the Chrysler cranks to fit. The Ford motors' bore centres are the same (or very, very close) the the Holden ones.
Cheers...Dave
ok cool thanks well how about a 250 ford crank out of a iron crank has anyone done this type of thing before?
my mate used a ford 250 crank in his. worked quite well too. it now has a CRS blower kit also. pretty mean HR sedan now!!
DO NOT WRITE BELOW THIS LINE
