Mr Void Offline
#1 Posted : Saturday, 20 August 2005 3:17:12 AM(UTC)
Mr Void
As per the title I am wanting some advice as to where the battery should go out of a 1 tonner..
I'm wanting to clean up the engine bay, the little things are easy enough to move but where can the battery go? I want to do it so the whole lot will eventually be legal but can only think of two places;
1) As far as engineering goes, would it be legal to make a vented compartment inside the large trusty toolbox on the tray and run the cables over the front panel on the tray (saves making holes in the tray) and into the compartment??
2) Or will I need to get one of those under tray boxes the tradies use and whack it in there??
Any suggestions would be great, thanks all....
___________________
Why are you reading this, you should be looking up there^^
___________________
#2 Posted : Saturday, 20 August 2005 6:05:37 AM(UTC)
When i had a 1 tonner.i made a little box with no lid under the tray, opposite side to the fuel tank. I then used a correct battery box and bolted in the battery box and the cables just exited thru the top.i used a dry cell battery,cost about $400, but th
#3 Posted : Monday, 29 August 2005 8:46:33 AM(UTC)
I made a battery box holder that is located behind the cab at the right corner (no fuel tank) as most electricals on the chev are on the right and lpg lines on the left.
pic here: http://gallery.oldholden..._battery.jpg.html?g2_ima
Mr Void Offline
#4 Posted : Monday, 29 August 2005 10:54:23 PM(UTC)
Mr Void
Thanks Frank & Danny,
They were the only two other places I can really think of putting it too..
Danny - do you know if there are any legal probs with having the battery there? Changing it will be a pain (within reason) but is there any probs with r
___________________
#5 Posted : Tuesday, 30 August 2005 5:33:50 AM(UTC)
