#1 Posted : Saturday, 20 August 2005 5:02:12 AM(UTC)
Hi guys i want to know if a XF 4speed manual 6 cyl(sedan) fit into a XB 351 auto coupe, can it be done?
#2 Posted : Friday, 26 August 2005 7:23:26 PM(UTC)
Teah it can be done but why not go for a later T5 instead eg. I used ED T5 behind 302c. Used adapter kit supplied by dellow and had flywheel modified to take 11inch RPM race series clutch. T5 (6 cylinder version) input shaft is same as standard single r
wayne Offline
#3 Posted : Friday, 26 August 2005 8:04:21 PM(UTC)
wayne
needs v8 bellhousing other wise ok
First
On
Race
Day
#4 Posted : Wednesday, 31 August 2005 5:20:33 AM(UTC)
#5 Posted : Wednesday, 31 August 2005 5:24:53 AM(UTC)
#6 Posted : Wednesday, 31 August 2005 7:29:11 PM(UTC)
is 5 speed gearbox used in EA through ED (BW-T50D). The version I used was from 6 cylinder ED falcon. The input shaft is the same size as xf single rail. It is basically a single rail 4 speed with a 5th overdrive added. It was an available option in t
Edited by user Wednesday, 31 August 2005 7:43:11 PM(UTC)  | Reason: Not specified
#7 Posted : Thursday, 1 September 2005 2:58:45 AM(UTC)
#8 Posted : Thursday, 1 September 2005 3:29:02 AM(UTC)
Dellow Automotive is at http://www.dellowauto.com.au
just make sure that you have all the gearbox details so that you get the correct kit.
Good luck.
#9 Posted : Friday, 2 September 2005 3:50:29 AM(UTC)
[quote]Originally posted by Insaen
Good luck.
Thanks for all you gave to me, its been very helpfu
#10 Posted : Friday, 2 September 2005 9:12:42 AM(UTC)
you will need a v8 bellhousing
#11 Posted : Friday, 2 September 2005 9:18:26 AM(UTC)
thanks for your reply wayne, not sure to get my hands on one yet, but i might give it a go!thanks.
#12 Posted : Wednesday, 7 September 2005 2:02:22 AM(UTC)
Get a T5 instead
#13 Posted : Wednesday, 21 September 2005 10:13:12 PM(UTC)
I am thinking of a similar conversion for my XB coupe, to replace the existing single rail. The info in this thread was really useful for me too but I have a couple of questions still:
1. Why use the T5 from a 6cyl and not a V8 version?
2. Will a T5
#14 Posted : Thursday, 22 September 2005 4:34:47 AM(UTC)
I only used 6 cylinder version in my example as it was what I used. You could use the v8 version but i think the input shaft is different...and possibly they are not as available as 6 cylinder version?? I think the box itselt is still the same.
From wh
#15 Posted : Thursday, 29 September 2005 11:30:58 PM(UTC)
Thanks for the info, I'll start looking for a gearbox now. If the 6cyl is strong enough I'll just use one of those, as they are only around $500 secondhand versus $2500 for a V8 T5 (in Perth anyway).
At that price I can afford to blow a few!
#16 Posted : Friday, 30 September 2005 9:48:04 PM(UTC)
I think that you have 2 options with the bellhousing if you use an XF-EL T5. The first is to buy a V8 T5 bell housing either from Ford, Dellow or CRS & the second is to buy a V8 toploader/single rail bellhousing and a sandwich plate that bolts the T5 to t
Guest (12)
This page was generated in 0.143 seconds.
