#1 Posted : Wednesday, 24 August 2005 3:37:42 AM(UTC)
i was wondering if the power windows out of a vk calais will bolt straight into my vh, and if there is any mods i will have to do?
#2 Posted : Wednesday, 24 August 2005 6:06:54 AM(UTC)
The Power Windows from a VK or even a VL will fit straight into your VB, VC, or VH however you may need to modify the Window Harness to be a 'stand alone' Harness or at least modify the plug for power supply and circuit breaker to mate into the correct sp
#3 Posted : Wednesday, 24 August 2005 6:09:21 AM(UTC)
Yep, they will go straight in.
The wiring is different - in a VK it is sourced from the engine bay fuse box, and has a thermal breaker, but in a VH it is sourced from a heavy gauge plug under the dash (fitted to all VHs) and runs through a circuit brea
#4 Posted : Wednesday, 24 August 2005 6:31:31 AM(UTC)
thanks for all your help guys, i'll give it a go this week
