i was wondering if the power windows out of a vk calais will bolt straight into my vh, and if there is any mods i will have to do?
The Power Windows from a VK or even a VL will fit straight into your VB, VC, or VH however you may need to modify the Window Harness to be a 'stand alone' Harness or at least modify the plug for power supply and circuit breaker to mate into the correct sp
Yep, they will go straight in.
The wiring is different - in a VK it is sourced from the engine bay fuse box, and has a thermal breaker, but in a VH it is sourced from a heavy gauge plug under the dash (fitted to all VHs) and runs through a circuit brea |
thanks for all your help guys, i'll give it a go this week
