edelbrock1 Offline
#1 Posted : Friday, 26 August 2005 2:46:22 AM(UTC)
edelbrock1
Hi Guys,
I have a mate who wants to convert his HQ to power steer. He has a steering box and pump, but no brackets. It is a HQ 202. I thought VK brackets may work, but before going out and buying some I thought I would ask first. So what is the best and cheapest option here?? What brackets can we use???
#2 Posted : Friday, 26 August 2005 2:48:52 AM(UTC)
Use the VC to VH bracket for the pump mounted on the top driver's side.
Make sure you also get the spacers and the rear brace. The screws throught the timng cover are also required.
Warren
#3 Posted : Friday, 26 August 2005 3:37:48 AM(UTC)
You may have trouble finding the rear brace. I rarely see them on Commmodores. As per Warren's comments I also stress that you get the spacers and original bolts. There's three longer bolts and 3 spacers where it bolts onto the thermostat housing, plus th
#4 Posted : Friday, 26 August 2005 3:55:15 AM(UTC)
Yep, 6 cyl Commodore Power steer brackets are HEAPS easier to find than HQ - WB ones. Also, the VC - VH (Blue Motor) front pulleys for power steer and air are much more common than the early version and fit the early 6's too.
The VK has a different pum
#5 Posted : Friday, 26 August 2005 5:21:01 AM(UTC)
If you post a email address I will forward you a scan of how the whole thing go's together, this also give the spacer sizings, I also have a spare 6 cylinder main bracket, if you need one, also the front pully used on the starfire 4 is the same pully for
RussVRute Offline
#6 Posted : Friday, 26 August 2005 7:01:24 AM(UTC)
RussVRute
Edited by user Friday, 26 August 2005 7:09:11 AM(UTC)  | Reason: Not specified
edelbrock1 Offline
#7 Posted : Friday, 26 August 2005 8:12:06 AM(UTC)
edelbrock1
edelbrock1 AT hotmail.com
Any help you could give us would be great!
#8 Posted : Saturday, 27 August 2005 2:19:23 AM(UTC)
edelbrock1's mate here (who wants to put power steering on an HQ 6) - just joined to get the lowdown and hopefully contribute as I can..
mang01 at ihug.com.au for that information for me too please if possible!
Thanks in advance for all who have contri
#9 Posted : Saturday, 27 August 2005 6:33:23 AM(UTC)
no problem, just give me a few days & it will be sent.
Kevin
#10 Posted : Monday, 29 August 2005 6:26:26 AM(UTC)
For all who wanted the scan of the power steering on red sixes, follow the link to my shed on oldholden....
http://gallery.oldholden.com/MONARO_MAD/album223/
Kevin
This page was generated in 0.111 seconds.
